Originally Posted by
bhvrdr
As an FYI, Mustang dynos (like all others) can read all over the place. Sure there are people that like to call it the "heartbreaker" but in reality they can read high as hell too depending on setup.
OP, before you run around town hopping on other dynos that you have no baseline from... see if you can ask the owner about other dyno runs he has in his database from stock cars. You may get a better idea how that dyno reads. Also you mentioned your car has a custom tune so there should unquestionnably be several baseline dyno runs and tuned runs available to you from your own car. If your car baselined at 240whp... well there ya go.
The best thing to do though would just be to have someone log your car and then spend 20 bucks (instead of 100 bucks on a dyno) at you local 1/4 mile track. Those things will help you know exactly where you are.
You may be making crap for power or not. you need more data first to be more certain where your car currently stands.
Mike
This. Dyno's are only accurate if you have a baseline, upgrade, re-dyno in similar weather conditions with same fuel, and calculate the delta.
Other stock car dyno sheets can be helpful, but each cars vary in power output quite a bit.
Oh, and tires make a difference as well (snow tires can sap about 10% whp on the dyno).
Transmissions can affect whp as well
Type of fuel will affect the whp greatly
Weather
How adapted your tune is (need multiple pulls without getting heat soaked to see what the engine likes)
Its a rough dick size measurement at best.
