Results 1 to 13 of 13
    Sep 21 2015
    Indiana
    B8.5 Misfire Issues
    I'm having issues with my 2014 A4. I was due to change the PCV for some time due to O2 Sensor Codes (O2 Sensor Bank 1 Sensor 2 Delayed Response Lean to Rich, O2 Sensor Bank 1 Sensor 2 Delayed Response Rich to Lean, Catalyst System, Bank 1 Efficiency Below Threshold). The car seemed to run ok up until last Wednesday.
    The temperature outside warmed up (30 to 70 in 3 days) and when I got home on Wednesday, the car started misfiring at idle when I pulled into my driveway.
    I let the car sit for a few days thinking maybe it was just the PCV issue, and I really needed to get off my ass and change it. I replaced the PCV, and the car is definitely running better. I'm not getting anymore O2 Sensor Codes, but I still have a misfire on Cylinder 1 and a Random Misfire CEL.
    I replaced the spark plugs this morning and swapped the coil packs around.
    Now I'm getting an additional P125000 (Fuel Level too Low) code. I have a full tank of gas.
    I had a carbon cleaning about 10,000 miles ago along with new fuel injectors.
    I haven't run a compression test yet on cylinder 1, but I'm working on that.
    Any ideas?
    Mar 25 2018
    Could be the high pressure fuel pump. How many miles on the car?
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    I assume that after you swapped plugs and coils around you still got the same cylinder #1 misfire. (plus the new fuel level low code).
    The compression test is a good idea. Sounds like its a fuel delivery issue. But youll have to take a fine tooth comb to everything air to track down the culprit. Maybe one of new injectors is bad or clogged.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Sep 21 2015
    Indiana
    Quote Originally Posted by adamleaf8601 View Post
    70,000 miles.
    Sep 21 2015
    Indiana
    Quote Originally Posted by audrobotic View Post
    Yes - it's still cylinder 1 after plugs / swapping coil packs.
    Sep 21 2015
    Indiana
    Just tested the compression. Cylinder 1 is about 10% lower than the rest.
    Established Member Two Rings DannyFB8's Avatar
    Jan 23 2017
    2021 B9.5 A4 | 2020 B9 SQ5 FBO
    JC, NJ
    Sad to say, this sounds a little all to familiar. Your next test should be a leakdown test. Had similar symptoms on my b8.5 throwing excessive misfire codes even after changing, injectors, pvc, new plugs. Did the leakdown test and cyl 1 kept failing and came to find out I had a scorn cylinder 1.
    Sep 21 2015
    Indiana
    Quote Originally Posted by DannyFB8 View Post
    I drove it today while watching the misfire counter. It only seems to do it at idle. It doesn't do it when I step on the gas. Did you have those symptoms?
    Jan 23 2017
    JC, NJ
    I had misfires at both idle and while pressing on the gas. Car was reluctant to start but after a couple of crank it did but I had also multiples other symptoms that supported the scorn cylinder such as oil leakage between timing chain cover and head block, 0 compression from cyl 1, oil deposits. Are you getting any of those?
    Sep 21 2015
    Indiana
    Not yet, thankfully. Compression seems ok on Cylinder 1 and no oil leaking or excess burning. Seems like it's either fuel related or a vacuum leak.
    Sep 21 2015
    Indiana
    Update - Replaced the breather tube, removed the O2 spacers I was using before I was tuned, and tightened down the PCV a bit more.
    The seems to be idling normally now and the ticking sound is gone. Cylinder 1 seems to misfire still when I let off the gas. Might be another vacuum leak somewhere...
    Sep 21 2015
    Indiana
    Update to the update: it was a failed fuel injector. Ironically, I replaced the injectors 10,000 miles ago.
    The car was much better after that last update but got progressively worse. I replaced the O2 sensors because I had been getting a delayed response error. It didn't fix the cylinder 1 misfire. So I replaced the fuel injector feeding cylinder 1.
    Hope this helps the B8.5 guys.
    Senior Member Two Rings rockstar143's Avatar
    Oct 01 2013
    United States
    Quote Originally Posted by ferndj02 View Post
    This not only helps but confirms issues I've been following as well.
    I did a valve cleaning and after that have been chasing down a misfire as well.
    Finally I tracked it down to one injector, new one is on the way.
    SO annoying but once it's all figured out I will feel like an expert.
