Results 1 to 12 of 12
    Junior Member Two Rings
    Dec 06 2017
    Upstate NY
    Scratch repair on Sepang Blue
    Found a 2" scratches on the hood of my 2018 Sepang Blue S6
    Brought the car to one of the larger local body shops for an estimate.
    They told me that they CAN'T MATCH Sepang Blue color!
    Therefore, they suggested repainting the whole hood to the closest color they can manage, and then blend this color into the fenders.
    The total is about $1,300. And, of course, the hood and fender will be not Sepang Blue anymore. Additionally, any professional looking at this car would tell that hood and fenders were repainted - and who knows what the extend of the damage was before the repair... It will look like the car was involved in an accident!
    My biggest concern is potential development and spread of corrosion from this place.
    I would prefer to fill the scratch with primer and the closest blue color, and level it.
    It would be visible at close inspection, but I think it is better than what this body shop offered.
    Of course, I will take it to other shops.
    How would you deal with a small damage like this?
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    Where on the hood is it? If it's on one of the sides before the center raise section you're in good luck. You can just mask off that side section to the raised line creating an edge. After color and clear it can then be buffed in melting the edge that was left back into the clear. Because it's right on the body line and the high point it will transition just fine. Can't speak to why they can't match the Sepang, I have Glacier and we did this exact technique with amazing results.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Nov 06 2017
    Iowa
    Find a different shop.
    Mar 29 2014
    Hampshire, UK
    You need to change bodyshops.
    I managed to get 2” scrape on the drivers side rear wheel arch. Body shop repaired and blended my sepang to a perfect match and you would never know it had been repaired.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Dec 06 2017
    Upstate NY
    Quote Originally Posted by madyspop View Post
    Unfortunately, it is right in the center of the hood..
    - - - Updated - - -
    Quote Originally Posted by Phantom75 View Post
    I will definitely try a few more shops.
    Nov 19 2005
    Central IL
    Quote Originally Posted by ZodiacPhoto View Post
    - - - Updated - - -
    I think the same technique would work, they’d just shoot the center portion taping from edge to edge of the body line. I’m actually going to my shop today to check progress on my bumper so I’ll ask for you.
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    That's the dumbest thing I've ever heard a body shop say. Lol find another shop who can get the paint matched based on the paint code in the trunk.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Dec 06 2017
    Upstate NY
    Veteran Member Three Rings 4Chio's Avatar
    Mar 14 2005
    STL
    IMO and I A person who loves A perfect car not worth fixing .
    2018 S6 Prestige ,sport, JB4
    2014 991 Cab C4S
    2018 S4 Prestige
    2017 Q7 Prestige
    (sold)
    2016 S3 Monsoon Gray Prestige | Sport seats| 19's W/ mag ride| Milltek Res valve
    2013 X5 M, 08 A6 4.2 Sline, 08 :.R32 ,07 S4 White/Black, 04 S4 6MT,
    Mar 08 2017
    VA
    Is the scratch really deep? It not I would just passing correct it... Pretty easy to get out
    Dec 06 2017
    Upstate NY
    It is deep - to the metal.
    It can't be just buffed out - it must be filled with paint.
    However, since the hood is aluminum, maybe corrosion is not as much of a problem as it would be on steel.
    Veteran Member Three Rings delz05's Avatar
    May 16 2014
    2013 Volcano Red S5 Cabriolet 2016 Glacier White A8L
    Boston area
    Matching the paint should not be a problem, if the shop has a paint mixing process... If they buy "ready" mixed paint, no such luck...
    Also, be advised that each of the metallic and pearl based paints have "variances", which means that while the paint code may be X1Y, these will be a variance code (lighter, darker, more coarse, more fine, etc...) that has to be matched to the car itself. A quality repair shop will have the paint cards with each variant, which is matched to the panels of car, IN DAYLIGHT, not inside a shop.
    It is an extra step that a shop will take and should take, to make sure that the paint matches what is on a vehicle.
    Family comes First!.... Nice cars a close second.
    For topless Summer fun... 2013 Volcano Red S5 Cabriolet Prestige, Black Optics Grill, Rear Valance, Tint, IE Down Pipes... SOLD!
    Semi-Daily Driver: 2016 A8L, Glacier White... Where to begin with the mods??? SOLD!
