Results 1 to 23 of 23
    Aug 28 2017
    Kansas City
    Armrest Latch Clip Replacement
    When looking at buying a new lid for my broken armrest I found that I can order just the latch clip from China for 1.60 an aliexpress. Has any replaced just the Broke clip instead of the whole lid?
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    Did the clip
    Today I found out it’s broken again
    New lid is the same thing.
    Don’t bother in my opinion
    Nov 12 2015
    Orange County
    I ended up replacing the entire lid for about $15 because the stapled leather ends were becoming undone. There are two different variants of lid/latches that aren't interchangeable.
    Aug 28 2017
    Kansas City
    Quote Originally Posted by Dondbg View Post
    Did the clip
    Ordered 3 of them to try out. Most ill be out is $6. I really dont want the armrest at all but I dont want the hole either from removing it. Maybe if it doesn't work ill glue the whole thing shut
    Established Member Two Rings Jargon's Avatar
    Dec 01 2017
    Oregon
    Quote Originally Posted by Audia483 View Post
    I did. Worked great. Six months later it's still fine. Worth $6 imo if the cheap china ones don't work out for you.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2006 A4 Avant 2.0T Quattro 6MT
    2003 BMW 325i Touring 5MT
    Aug 28 2017
    Kansas City
    Quote Originally Posted by Jargon View Post
    Thats exactly what I bought from china. Guy is using the same stock photos. The seller is probuly buying in bulk from and reselling. Only downfall is it takes 2-4 weeks to get
    Mar 24 2013
    Oakdale, CT
    I bought the aluminum latch off of ebay that will never break and put that in.
    -Adam
    Established Member Two Rings csevans's Avatar
    Apr 03 2018
    2018 Ford Escape Titanium
    Champaign, IL USA
    I went through 3 different replacement covers until I got the right one. All were advertised as fitting my 2007 A4. Be prepared for the same with the clips.
    2007 Audi A4 2.0TFSI Quattro. Auto. Brilliant Black (LY9B).
    Billy Boat Cat Back Exhaust. GFB DV+. APR Stage 1 ECU.
    034Motorsport Density Line Motor Mounts - Street Density, Performance Polyurethane Snub Mount, Active Motor Mount Resistor Bypass
    ECS Audi B6/B7 A4/S4 Front 32mm & Rear 25mm Sway Bar Kit
    034Motorsport Density Line Complete Front Control Arm Kit
    Bilstein PSS9 Coilover System
    Interior has been (mostly) fixed.
    Betty got a nose job. More to come.
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    Replaced only the lid for $2. It is not perfect fit as original, but works. Has been a year and still okay.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    Quote Originally Posted by zeitmorder View Post
    also happened on mine but it doesnt bother me enough to replace it..
    Veteran Member Three Rings king_j's Avatar
    Sep 09 2009
    Minneapolis
    I bought the lid from amazon 2 years ago. Still works fine.
    Looked at clip replacement, but really not worth the time to replace it.
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
    Me too! A little more expensive, but worth every penny! The ones from china will break in no time.
    Established Member Two Rings TransAm87WS6's Avatar
    May 27 2012
    1969 Camaro Z/28, 1981 Corvette, 1987 Trans Am, 2002 Camaro Z28
    Glen Cove, NY
    I did, well over a year ago, probably closer to two - been fine ever since. Color (Platinum) was dead-on too...
    Just make sure you order the right style, phone package (flat end) vs non phone package (rounded end)...
    Established Member Two Rings kingVR's Avatar
    May 23 2011
    Ontario, Canada
    I got a new eBay clip. How do you install? Here you go:
    B7 Center Console Latch Replacement
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Last edited by kingVR; 11-17-2019 at 04:37 PM. Reason: Found thread with instructions
    May 23 2011
    Ontario, Canada
    So the new latch protrudes 3mm longer. Did they send me the wrong one or are they all like this?
    eBay item #254408183362
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Thats the one I bought as a replacement, its fine, its a cheap knock off. I removed my arm rest, its useless to me and it gets in my way. Take it out, its amazingly roomy with it gone.
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Nov 10 2019
    Chicagoland
    Do you have a link?
    Established Member Two Rings TheChenga's Avatar
    Jul 12 2012
    Australia
    Quote Originally Posted by kingVR View Post
    Got the same replacement, must be for the B6 but still fits regardless. Replaced my clip 1 year ago and no problems.
    APR
    Feb 18 2018
    south lake tahoe, CA
    Hey, Ive been looking for the aluminum latch but can't seem to find it anywhere. Can you send a link please?! Thanks
    -Peter
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by audiwon View Post
    -Peter
    Doesn’t appear to be available on ebay anymore.
    -Adam
    Senior Member Two Rings S3 lover's Avatar
    Dec 07 2016
    Glendale, CA
    I just bought the whole armrest top with the clip for like $12 off amazon. Good fit and latch works perfectly
    Aug 03 2019
    NoVA
    x2 for the Amazon clip latch. Has been great for 6 months. Just be gentle as they are just plastic and almost designed to fail.
    In for the AL one if found again...
    May 23 2011
    Ontario, Canada
    I am good with the cheap replacement latch so far. I think all these broken latches are caused by letting the lid slam shut. Close the lid slowly and it should last.
