Results 1 to 11 of 11
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Joining the Blown Turbo Club
    Just wanted to share. I know I’m not alone here. I’m suddenly seeing a bunch of you in the same boat.
    I thought I’d share my symptoms here. Last month I was driving the kids to school early morning and had the S7 lose power and stall while merging onto a busy road. The car eventually started after a few attempts and I thought nothing of it.
    Fast forward 3 weeks and my wife in her Q5 parked next to me is telling me my car sounds terrible and points out a clicking noise at idle.
    The next day my car stalls out after a rough idle. My idle was fluctuating between 500 rpm and 1100. The stall and rough idle continued the next day and eventually the S7 died on the way to drop off at my shop.
    Had it towed and diagnosis came back blown turbos. My tech told me the front of the shaft seemed functional with some minor scoring on the inner wall of the housing. Eventually he was able to access the back of the shafts and the driver side rear was cracked.
    Anyway, I was able to locate a used set of turbos from a member here which saved me a good amount. The part quote for the kit including the turbos, gaskets etc. was $5000. The turbos were $4100 of that. Ouch..
    The car is getting fixed and will hopefully be ready early next week. Now what?
    I’m debating if I’m keeping her longer or move on. Lately my driving consists of 25 miles a day of mixed highway and some back road twisters but the car mostly sits in a lot. I’m thinking, time to move on but I know I’ll miss the power, comfort and sportiness of the S7.
    Anyway.. I vented. I hope I don’t see any more posts of blown turbos.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    how many miles on the car?
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    42k miles. Stage 2. But never run hard.
    Established Member Two Rings mj1903's Avatar
    Jan 03 2018
    2014 Jaguar F-Type V8 S, 2009 Tahoe LTZ, 2016 Yamaha YZF-R1, 2001 Suzuki Hayabusa Turbo
    WI
    Did you have any of the turbo campaigns done? Any previous work on the car that would involve removing the turbos and reinstalling? Also, what year?
    2013 Audi S7 - EPL Stage 1 ECU and TCU, Eurocode front and rear sway bars with endlinks, Milltek resonated catback exhaust, K&N air filter, Havanna Black Metallic, black interior, Innovation package, comfort seating package, LED headlight option, 20" x 10.5" MRR GF6 summer rims with Bridgestone Potenza S-04 Pole Position 285/30R20 tires x 4, Carbon Atlas Inlays, Cold weather package, rear side air bag option, RS7 style front grill, 3M front clear bra package, 3M tint package, VCDS lowered 17mm.
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Bummer, sorry to hear. Are you saying you got the used turbos for $4100, or was that your quote for a new set? also would you mind going into the 4.0TT sub-forum and putting your info in the blown turbo poll?
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    I'd keep the car, the money is spent so you know the turbos are good now.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Good for how long? If we're replacing blown turbos with the same turbos, will they not eventually fail? I need mine to hold out until September when I deploy. Upon return, I may have to bail on the S6, which is a shame, because Stage 2 is pretty sweet. I'm at about 63k miles, about 35 of which have been tuned, and the last 5-10k of which have been Stage 2.
    Quote Originally Posted by ericw. View Post
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    Apr 23 2011
    Sac Area, CA
    Quote Originally Posted by Brooklyn View Post
    The problem isn't with the turbos, it's gotta be something else causing the turbo to fail prematurely. There's a recall on oil lines to the turbo, did you do the recall?
    IG @lolzhax
    //AGILITYDRIVES.US
    May 08 2004
    NoVA
    I don't believe i've had any turbo work done. Only recall/TSB I recall receiving was related to the coolant system, and I believe all the dealer did was change the software. May have to look into it when I get back from this trip.
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    I haven’t had any dealer campaign done on my car. $4100 was the dealer quote for a pair of new turbos. Was able to pick up a set for $1500.
    I didn’t realize there was a poll going. I’ll look for it.
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Gonzoe, out of curiosity, how often have you been getting oil changes and which oil have you been using?
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
