Results 1 to 20 of 20
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Autotech HPFP installed with bad results...
    I recently had the Autotech HPFP upgrade installed and logs are showing 20,000+ less actual rail fuel pressure then stock. Anyone else running this and have better luck?
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    It must clearly be defective or been installed wrong. Never heard anyone with this issue before.
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Jul 02 2017
    2012 VW GTI, 2015 Nissan GT-R Premium
    Smyrna, DE
    Sorry to reply with another question, but what is an average max fuel rail pressure at WOT at 6800 or 7200 rpm for a stock fuel pump setup?
    Nov 12 2006
    Michigan
    Quote Originally Posted by SGR View Post
    I'm not sure but I also have GIAC LPFP upgrade.
    Nov 12 2006
    Michigan
    Is there a way to instal this wrong? Seems pretty straight forward. I would love to see logs of others running this setup to compare, anyone?
    Jul 02 2017
    Smyrna, DE
    Quote Originally Posted by elijahallen View Post
    Well, still curious, what was the pressure (hPa I assume?) you were getting before the install?
    Jul 02 2017
    Smyrna, DE
    I’m seeing 136000-138000 hPa on 30%-ish ethanol blend. I just have the autotech upgrade, no LPFP upgrade.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I swear Lou posted that there was an issue with the return flow not being able to keep up on - so the pump would suck the bucket dry - and then fuel pressure would drop - Fix was a small add on pump (IIRC)....
    I tried searching - but had no luck - You may want to PM Lou for specifics?
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Senior Member Two Rings redlinerex's Avatar
    Jul 03 2015
    Folsom, CA
    I believe somebody else had a similar issue a couple years back and it was also the Autotech HPFP upgrade. 99% sure it was Grumpy and after Autotech sent him a new one, all was good.
    Nov 12 2006
    Michigan
    Quote Originally Posted by redlinerex View Post
    Good to know.
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Hofame has a similar issue and now I have his auto tech. 🤪
    Logs will tell soon
    Sent from my
    '18 S5 - BBS / EPL
    Nov 12 2006
    Michigan
    Before the pump I was seeing 117,000 hpa, after I am seeing 95,000
    Nov 12 2006
    Michigan
    Thanks, I was hoping to hear what it was supposed to be at. Mine dropped from 117,000 to 95,000 with Autotech added.
    Jul 02 2017
    Smyrna, DE
    If you’re seeing max of 95 hPa at any given time (i.e., not higher initial pressures at WOT then pressure dropping later in that same WOT pull), then I don’t think that is indicative of the issue of the fuel bucket running out...
    Jul 02 2017
    Smyrna, DE
    Np.
    Nov 12 2006
    Michigan
    Without the Autotech HPFP at WOT in 4th gear I was seeing requested at 122000 and actual at 117000, now with the new HPFP I am seeing same requested and 95000, I have a track event coming up in a couple weeks and need to get this sorted so I don't lean out on track and blow the motor.
    Jul 02 2017
    Smyrna, DE
    Have you gotten any codes? In any case, I’d give autotech a call when they next open. I’m sure you’ll get things sorted out soon.
    Nov 12 2006
    Michigan
    No codes but I got it installed, drove it home and did some logs to make sure it was worth the $400 lol. The weird part is the car feels faster but that could be because its going lean. Cars are always fastest right before they blow up haha
    Feb 21 2017
    Denver
    Can anyone post their hpa with autotech working properly? I'm curious to check mine now.
    Jul 02 2017
    Smyrna, DE
    Quote Originally Posted by Callandor View Post
    I did a pull at WOT in second gear earlier today and got got a reading of approx 146000 hPa at around 7100-7200 rpm. Running E30 currently.
