Hi guys
My OG fuel pump went out in my car last year. Replaced it with a used one from a parts car I had, and low and behold the check valve in that pump doesn't work. Car takes multiple tries to start after letting it sit for a while.
Instead of replacing the pump AGAIN with an aftermarket one, I figure I'll just put in a check valve.
I was just wondering where you guys who have done this put the check valve. I've seen some people say they put it on the feed line that comes from the fuel pump up to the top cap on the tank (the plastic hose), but I don't know how well it would seal since it's corrugated the whole way.
Another option would be right at the outlet of the cap on the tank, but the problem is that the hard lines that go to the engine are pretty tight in there and adding a whole check valve will make the hard lines hit the body of the car.
So where have you guys put yours?
