Results 1 to 10 of 10
    Jul 06 2012
    Rockaway, NJ
    Jerk from 2-1 shift DSG
    Noticed today when coming to a stop that my car would jerk or "clunk" a bit. Haven't gotten any gearbox warnings, check engine lights, etc...any idea what it could be? Thanks everyone.
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Could be normal, but there's a lot of info on this subject. This is a start:
    https://www.audizine.com/forum/showt...nd-of-Failure)
    Jul 16 2012
    Mid-Atlantic
    Yea. Really common problem solved by a tune and inserts. Probably 100 threads on it.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    put on your flame suit as a search will bring back a ton on this.
    Is a bit normal if your new to the DSG or could be an issue coming.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jul 06 2012
    Rockaway, NJ
    Thanks guys. I'd imagine if it were the mechatronic unit I would be getting a gearbox warning, correct? I am new to dsg as I just came from a b5 s4.
    - - - Updated - - -
    What do you mean by inserts??
    Aug 19 2017
    2018 Acura MDX, 2018 Volvo XC60
    Larkspur, CO
    Quote Originally Posted by idonthaveanaudi View Post
    Are you or the car shifting from 2-1 while still moving? My car won't shift back to 1st (by itself) unless at a complete stop and is completely smooth. I think if you're still moving that the general consensus is that you should avoid manually down shifting to 1st with the DSG.
    2015 Daytona Grey S4 | DSG | Sport Diff | Tech PKG | B&O | Napa | Carbon Atlas | CR-15 | Injen Intake | Chipwerke Pro | VMR V804 Hyper Silver 19x9.5 | Michelin Pilot Super 4S 265/35/19 | OBDeleven mods
    Jul 16 2012
    Mid-Atlantic
    Quote Originally Posted by Jeagle View Post
    I downshift to first all the time. Great sound.
    Aug 19 2017
    Larkspur, CO
    Quote Originally Posted by Works2shoot View Post
    It does sound great... I try not to do it often to avoid stress on the DSG. I can't wait to go stage 2 so I have more pull at lower RPM's so I can pull harder in 2nd and avoid the urge to downshift to 1st LOL.
    Jul 16 2012
    Mid-Atlantic
    The car has to switch to first anyway upon slowing down. It’s designed to be able to switch through all gears hence the throttle blip. The perceived stress is due to bad programming and a mount that moves too much.
    Beauty of computer controlled rev matching!
    Jul 06 2012
    Rockaway, NJ
    The car itself is shifting. I dont really keep it in the manual shifting. However, I didnt realize traction control was off...turned it on and now I haven't had an issue in the last 30 mins or so I drove it. Any connection between the two systems?
