I'm trying to troubleshoot if my cooling system is working properly on my 2.7T 2004 A6. When the car is running I can't see any coolant flowing into the reservoir. I was going to pull hoses off when cool with the car started and see if there is any flow. Does anyone have a diagram of the flow path?
I ask because I have a cheap OBD adapter just to see engine coolant temp. I was using Torque app on my phone and the temp would get to 224 degrees F so I thought the app might be screwed up. Then I got OBD car doctor app and the temp was fluctuating between 140 and 220 degrees F. The needle in the car stays at 12 o'clock and I used a fluke laser thermometer to measure the temps when the car was up to temperature. I got 180 degrees F at the highest spot and that was at the engine output hose to radiator. It's driving me nuts, I wish I never got the app and was just bliss in ignorance referencing the gauge in the car.
Is it possible that the sensor can be bad and no matter how high the temp gets the gauge will always stay at 12 o clock? I am thinking of machining an adapter that fits into the ECT port and accepts the ECT but has another port to screw in a temp gauge so I can see the "real" temp.
This is the reservoir. The two hoses I'm wondering about attach to the circled areas. Is coolant always flowing thru the hoses connected here? So if I remove them, coolant will come out while the car is running?
Please help me if you can.
