Well, I'm out of the car, but I cant start it.
The SAFE comes up on the dash in the Odo reading.
I've disconnected the battery, and shorted the terminal wires - currently doing that again.
The problem appears to have started with the key fob.
I replaced the banged up key fob with an aftermarket one - you move the guts of the old one into the new one. I also replaced the battery at the same time. Electronics are the same, but because the battery was disconnected from the key fob electronics, I suspect it lost is programming. Prior to doing the replacement, the indicator light on the key fob would flash, but the doors wouldn't open (hence the battery change).
Thats what started it. Went to test the replaced case this morning, and it didnt work. Jumped in to try to resync the key with the car (put key in ignition, turn to acc, hold keygfob button, turn off) and thats when this all started with the SAFE stuff.
So, found this in the forums (I believe it was an B6 RS4 thread ... I hope its the same, info on this is hard to find)
1. Disconnect the car battery for 10-15min. Shorting the leads.
2. Reconnect.
3. Put key in ignition. Turn to accessory position.
And here is where the instructions are all overr the place.
Some say turn it to accessory 5 times, leaving it in acc position for 10 sec.
Some say to do that while holding the door open/close buttons.
Urgent help needed. I have a ton of things that need to happen today, and if I'm not on the road soon I need to get on my bicycle and get to where I need to be ...
