Results 1 to 7 of 7
    Apr 07 2017
    Poland
    2.7t BES 2005 vacuum lines schematics
    Can anyone support me with BES 2.7t 2005 vacuum lines schematics?
    I am going to visit my friend who has a smoke tester to check the vacuum lines. With the schematics checking everything would be much easier.
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    You mean this?
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Oct 10 2017
    Sweden
    Or this?
    Audi TT 1.8T -99
    Apr 07 2017
    Poland
    Thank you! Much appreciated. Man, but this first schematic is huge. I don't think I will manage all those parts
    @ first I would like to look at:
    1. N75
    2. N8
    3. non-returning valves
    4. Vacuum reservoir (???)
    5. Mechanical air-recirculation valves
    6. N80
    7. Pressure limiting valve
    I've already learned that when mechanical-air recirculation valves are damaged, they have a vacuum leak, so it should be simple. And all non-returning valves- you just need to do the "blow" air test. What about others? Do you know how to check them?
    I've marked the components to be checked form the 1st diagram, is there sth more?
    Idle is sometimes very rough and car is jerking terribly when accelerating on low rpm. On high revs it runs quite ok, but there are occasional 1 second power cut-offs durng kick downs...
    When weather is cold car is running better. And I need to change both o2 sensors every 5000 km, cause they get damaged... After replacement car runs perfectly for a short time.
    All the time I get bank 1 and 2 system too lean errors.
    Junior Member Two Rings
    Apr 26 2014
    Queens, NY
    guys I know this is old but anyone has the part numbers for the first diagram? I'm looking for #10
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Quote Originally Posted by mo21 View Post
    No Longer Available. You could always run a flexible silicone line in its place.
    My hard plastic line broke so I put a ID 5mm silicone hose over it and clamped it to either side. Works great and cost me $0.50.
    Veteran Member Three Rings FatMongo's Avatar
    Oct 10 2019
    Kansas City
    Tagging for future review.
