Results 1 to 3 of 3
    Nov 05 2017
    Sydney, Australia
    KW DRC delete installed, still CEL
    Hi,
    My 2014 RS5 (with DRC) coupe’s standard rear shocks were leaking so I went ahead and purchased some Bilstein B8 shocks and KW DRC delete lit (I already had H&R lowered coils).
    The workshop has installed everything fine as per instructions but I am still getting a suspension related CEL.
    Has anyone installed the KW kit before and had a similar issue?
    Sent from my iPhone using Tapatalk Pro
    Jul 25 2011
    Check the connections for the EDC delete. One must be not connected properly. Even if 1 is disconnected it will throw up Error codes.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Did the guys doing the install delete out the codes after the parts were fitted?
    Did they fit the correct parts, there’s a kit for the RS5 - Part #: 68510358 and a kit for the A5, S5 - Part #: 68510476
    http://docs.kwsuspension.de/ea-KWSLS-h68510358.pdf
    Instructions to double check they installed it correctly.
