Results 1 to 10 of 10
    Dec 29 2016
    Des Moines/ Iowa
    Loud Whistling Noise- Error Code
    What's up family. Just checking in with someone who may know what's going on with the car. Check engine light came on today. There is a loud whistling noise when I decelerate and continues until I accelerate or shut down the car. See Error Code below. If anyone has any insight or can point me in the right direction that would be wonderful. Thanks!
    Address 01: Engine (------CEUC) Labels: None
    Part No SW: 4G0 906 014 E HW: 4H0 906 014
    Component: 4.0l V8TFSI / H62 0006
    Revision: NCH62---
    Coding: 1A2500326546000E1000
    Shop #: WSC 17741 002 1048576
    ASAM Dataset: EV_ECM40TFS0114G0906014E 001006
    ROD: EV_ECM40TFS0114G0906014E.rod
    VCID: 2412E6433E53E767360-8070
    1 Fault Found:
    4050 - Leak in Air Intake System
    P2279 00 [175] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 114674 km
    Date: 2018.04.12
    Time: 11:54:34
    Engine speed: 648.00 /min
    Normed load value: 7.5 %
    Vehicle speed: 0 km/h
    Coolant temperature: 103 °C
    Intake air temperature: 47 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 14.206 V
    Unlearning counter according OBD: 40
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Let me add this too..........
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
    Component: BCM2 2.0 H33 0433
    Revision: 00002001
    Coding: 0D8A2046000000000000
    Shop #: WSC 02391 785 00200
    VCID: 7BA0FD3FE3ED789F27A-802E
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Serial number: 2313000107604015
    1 Fault Found:
    00956 - Key 2
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 216
    Mileage: 108495 km
    Time Indication: 0
    Date: 2018.01.15
    Time: 11:08:27
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Sully, what are you driving? Unfortunately, many folks with a loud whistling noise on the 4.0T engines have had faulty oil separator/PCV replaced, which is an ordeal to get to. Otherwise, make sure you check you hoses for your air intake and that nothing is disconnected. Is your car still under any warranty?
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Dec 05 2016
    Westminster, CO
    Oil separator. Welcome to the club: https://www.audizine.com/forum/showt...arator-R-amp-R
    Dec 29 2016
    Des Moines/ Iowa
    Quote Originally Posted by OlyS6 View Post
    I’m driving 2014 S7, out of warranty
    Dec 29 2016
    Des Moines/ Iowa
    Quote Originally Posted by WhiteWhiteS7 View Post
    I think this may be the issue
    Nov 22 2016
    Olympia, WA
    Yes, unfortunately most likely. WhiteWhiteS7's DIY on replacing the oil separator is awesome and certainly doable in a weekend. If you aren't comfortable doing it after reading it, buy a new one that ends in 'E' (the part number on your current one likely ends in 'B') from audiusaparts.com and have an independent shop do it so you don't get crushed at a dealership.
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Too bad you don't live in like IC, otherwise I'd say we should have a wrenching GTG.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Dec 29 2016
    Des Moines/ Iowa
    Quote Originally Posted by justsully View Post
    Yea, I think it is the case. I would love to do it myself, but I'm at the mercy of time. Here is a video just in case you guys think it's anything else.
    - - - Updated - - -
    Quote Originally Posted by GilliamOS View Post
    I would sound like a whistling train driving all the way to IC. haha
    May 26 2015
    Mormon Country
    i would sound like a whistling train driving all the way to ic. Haha
    it's like wooo wooooooo!
    I should add I'm actually along the river, not in IC.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Dec 29 2016
    Des Moines/ Iowa
    I got an estimate from one of the best euro mechanics in town and he said it would cost $1540. Not too bad considering the all the time it takes to get the actual part. I wish I wasn't so busy with work, it would have been fun to tinker with it all. Thank you to all that contributed to helping me find out the issue. Cheers!
