Results 1 to 22 of 22
    Nov 23 2009
    NYC, US
    Stripped Thread (Oil Drain)
    Hi All,
    I went to a shop for oil change. The guy said why is it so tight to unscrew the oil drain plug. Then he found the plug went in tiled and some threads were stripped.
    I'm assuming the previous shop messed up my drain thread while trying to put the drain plug back on?
    Now the guy suggested me to get a tap (M14, 1.5) to refresh the thread of the oil drain hole. He said a brand new oil pan with labor would cost me $400. It is a 2010 A4 with 37k miles on it.
    I hate to see this happen on my car. I feel like the previous shop/guy should have told me this if he sensed the drain hole is worn..
    Any suggestions? Will re-thread the oil drain hole with the M14, 1.5 tap work? Or I'm looking to spend $400 to replace the oil pan?
    Jan 25 2013
    West Chester PA
    Re-threading can work on the oil pan. The threads will never be as strong as they once were but sounds like the guy at the last shop over tightened the drain plug. I would re thread the pan now as that is the cheapest option and keep a eye out for an used oil pan.
    Mar 15 2015
    Texas
    That happened to me, took my car at the dealership for 45K oil change and they changed it up and set me free. Fast forward 6 months, I was doing my own oil change at 55K and I found out my oil drain plug was completely stripped. Went back to the dealership, they removed the stripped oil drain plug and hooked me up with 2 plugs for free. I just went up to the parts counter and asked for oil drain plug, the guy came back with two different types of plugs. Below are the pictures, and he told me, we had a lot of people complaining about the black bolt so Audi revised it and now they use the silver one. He gave me both of em. The pictures are not mine but you get the point.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    After running the threads you could install a Fumoto valve, to avoid the need to keep removing the plug. Or get an extractor.
    2011 A4 Avant
    Nov 23 2009
    NYC, US
    so I need a tap which it is M14, 1.5? The guy told me that is the size of the tap. How can I verify that?
    Nov 17 2010
    Quote Originally Posted by AutoRacer100 View Post
    I can confirm that is the size of a spare pan plug I have. Keep in mind this is not a guaranteed solution since no one knows how bad the thread damage is.
    2011 A4 Avant
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    I'd try the tap. If it's successful I'd seal it with rtv and use an extractor from then on. I'd also keep an eye out for a decent price used pan as I would always be worried about that plug even if the tap "fixes" it.
    2011 A4 Avant Prestige S-Line
    Nov 23 2009
    NYC, US
    I was told that the oil drain thread is partially damaged and I saw there were metal strips which wrapped around the plug yesterday. So the shop used a new oil plug with some sealant grease to plug the oil drain hole. There is no oil leak while the engine is running.
    I see a brand new oil pan is about $135 at Europart plus labor.
    A Schwaben 6 liter oil extractor at ECS Tuning cost $170. I have never used an oil extractor before. I would assume the benefit of using an oil extractor is I do not need to take the car to shop for an oil change anymore? The con is any residues or metal shavings in the motor oil won't be removed by using an oil extractor?
    Veteran Member Three Rings NathanGreatScott's Avatar
    Apr 05 2017
    '16 Ford Flex Limited
    Western PA
    I just bought the schwaben extractor from ecs and used it the other day. It only cost me about $80 tho, not $170. The ease of doing the entire oil change without having to get under the car was soooo nice. I'm stilling going to drain it conventionally ever few changes, but with your situation, I would do what @jfo mentioned above. Tap your oil pan and use a valve type drain instead of a plug. Then you won't have to keep taking it in and out and possibly wearing the tapped threads.
    Nov 23 2009
    NYC, US
    Quote Originally Posted by NathanGreatScott View Post
    Where did you get the extractor for $80? Was it an used one?
    Is this tap to get? What does a metric taper do? I need only the plug tap right?
    https://www.amazon.com/M14-1-5-Metri.../dp/B00MHGH9KY
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    https://www.ecstuning.com/b-schwaben.../011885sch01a/
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Nov 23 2009
    NYC, US
    Apr 05 2017
    Western PA
    Yup, that's the one! ^^
    idk about the tap you'll need. If the guy at the shop suggested that one, id probably go with that
    Nov 23 2009
    NYC, US
    That one has some bad reviews on Amazon. Which company makes high quality taps as I need to making threads on steel (not soft aluminum), I may need something strong.
    Apr 05 2017
    Western PA
    Sorry, I have no experience with taps so I really don't have any recommendations. Heres a set that schwaben makes https://www.ecstuning.com/b-schwaben.../006258sch01a/
    I'd imagine if you walked into a home depot or something, you could find a decent set.
    Aug 17 2015
    California
    I have this one also, and it is awesome. Has held up well over 3 years and many oil changes!
    I still recommend a drain out the pan every so often.
    Oct 12 2007
    Sacramento, CA
    Hi All,
    I installed a time sert in mine,
    This is what I used when mine stripped out, Not much cheaper than a pan but easier to install,
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I also got shorter inserts
    Aidan
    2011 S4: 6 MT, Sport diff
    1990 CQ
    83 GTI
    1995 Land Rover Discovery 4.6
    It's all fun and games until you hear the German engineer say "spank me harder than a bottomed out suspension daddy"
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    It seems on newer cars of Audi and BMW, the idiots (I mean engineers) decided on these easily stripped hex screws instead of a traditional bolt....then, you have the other idiots (mechanics) using impact wrench or going way past gutentight on a part requiring 18-22 ft/lbs of torque. I just did mine and bought a kit on FCPEuro that includes a new bolt to replace the plug.
    1997 BMW M3
    CES Stage IV (651rwhp/615rwtq @ 24 psi)
    2020 S6
    Premium Plus, Black optic, performance exhaust
    2013 Audi A4 (sold)
    Prestige package, S-Line, 6-speed |IE Stage 2 | IE Performance Downpipe | S4 exhaust swap | ECS Luft-Technik intake | ECS Luft-Technik FMIC | RS4 grille | ECS SSK | ECS Trans/Diff Inserts |
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by rally3 View Post
    I've always heli-coiled. What is the advantage of these over heli-coils?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by mtroxel View Post
    I've used both. I prefer the time-sert.
    Feb 24 2004
    Minneapolis
    Can you cut them....make them shorter?
    Dec 28 2006
    Western Maryland
    Yep.
