Results 1 to 3 of 3
    Dec 16 2014
    Front Lower Rear Control Arm Bushing
    I'm getting a clunking sound when I make hard turns. I've been replacing control arms over the last couple of months and its still there. So far I've replaced both uppers, sway bar links and front lower. Upon further inspection I can't see any cracks in the front rear lower control arm bushing but it seems like thats where I feel it in the frame around turns. Just wondering if I'm missing something. I'm planing to replace my front lower rearward control arms but while I'm down there are there any other bushings I could be missing? Could the noise be from the subframe? Car has no accidents.
    Senior Member Two Rings Natejo91's Avatar
    Apr 05 2017
    Porsche Cayman S, Toyota 4Runner, Suzuki SV650
    If you figure this out, let me know. Last summer I replaced all of my suspension (didn’t have any popping noises before) and also did all of the front control arms. Car was quiet for a few months then out of nowhere I started getting a popping noise at low speeds. I thought it might be the sway bar bushings so I replaced the bushings on the brackets but couldn’t figure out how to replace the end link bushings. Popping noise is still there though :( but the car drives fine
    2003 B6 Quattro MT | Polar White w/ Ebony interior | B7 seat swap | B7 Center Console | JHM + Black Forest Shifter | B8.5 MFSW | RNS-E | Brembo 18Z calipers front | S4 rear calipers | S4 front sway bar | RS4 rear sway bar | Bilstein B8 kit w/ H&R sport springs | Bosch 550cc injectors | Tubular high flow exhaust manifold | K04 | 3" MAF | 034 Motorsport 3" test pipe | B7 Dual Sidemount Intercoolers and Motoza K04/Hybrid tune
    Junior Member One Ring
    Nov 01 2016
    Your top hats are probably worn out. An easy workaround is to add a washer or two under the nut at the top of the strut rod. Give it a try. You should have the special strut socket to do this job.
