Results 1 to 17 of 17
    Active Member Two Rings GanoMF's Avatar
    Jul 31 2017
    Central Florida
    What is worthwhile taking off an s4 for my a4 2.0
    Have a guy with an 05 s4 cabrio that he is parting out. I have a b7 a4 2.0 sedan and was wondering whats worth taking off it. Already considering:
    Rsb
    Fsb (only because mine is f'ed up)
    Front and rear calipers
    Was thinking of injectors, coil packs, front seats, hpfp, etc. Don't know if these or or anything else will fit or be an "upgrade". (I know seats will fit)
    Thanks in advance...
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    I'd normally say seats but hard to say with the cabrio if it's all plug and play and/or worth grabbing? Door blades are a no on cabrio doors as well.. Headlights depending on which ones he has and which you have, steering wheel could be an upgrade if you have the four spoke wheel currently.
    Pat
    F.T.W.L.T.B.D.W.I.C.T.W
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by GanoMF View Post
    Rsb
    His car doesn’t have a high-pressure fuel pump. The injectors won’t work in your car because the S4 is not direct injected. The coil packs aren’t an upgrade. The seats are marginally better in a Cabrio than an A4 because they’re not the B7 Recaro. There really isn’t much that’ll work other than the parts you mentioned and the front end body panels/headlights. If it has actual aluminum side mirrors, those would be an upgrade.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Deactivated Four Rings
    Jun 23 2011
    The S4 is not FSI, so the injectors will not work and it does not have a HPFP.
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    As for the brakes, for the front make sure you take the carrier as that is the main difference between the A4 and S4 fronts. Calipers are the same except for the interior curvature, the S4 calipers fit the 354mm rotor better. If the rotors are in good shape grab those as the A4 are 330mm and the S4 are 354mm. If they are too gone, you will have to buy new.
    For the rears, the rotors are different between the A4 and S4 so if the rear rotors are in good shape, grab those otherwise you will have to buy new rear rotors since the S4 rotors are a bigger diameter and also thicker due to the venting..
    The A4 dust shields will work for both the front and rear, but I think the S4 dust shields are a little different and will be a better match, so grab those as well.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Jul 31 2017
    Central Florida
    Quote Originally Posted by pw211 View Post
    Havent seen the car yet as its been raining, but its got the older headlights from pics. And as far as seats, mine aren't heated but are power, don't know if their would be any other plug and play issues. Mine are perfect but don't know if the s4 ones are different shape wise. Thanks btw.
    Jul 31 2017
    Central Florida
    Quote Originally Posted by james12lucy View Post
    Was looking @ audi part#s and the coil packs on the s4 seem to be the same as the r8 red tops people put on, so thats what made me think to take em. And front clip no good, different body. Why did you say the seats were marginally better if they arent recaros btw? And thank you as well.
    Jul 31 2017
    Central Florida
    Quote Originally Posted by Chris@EPL View Post
    I thought i remember seeing people getting something fuel related from s4/rs4 for their 2.0s. Maybe fpr or in tank pump, idr.
    Jul 31 2017
    Central Florida
    Quote Originally Posted by Older_not_Wiser View Post
    This I was looking into a little deeper to make sure i grabbed everything i could so as not to have to purchase new like you said. A4 shields fit, but if im gonna swap everything im gonna do them too. 3 more bolts, no biggie. Thanks.
    Jul 31 2017
    Central Florida
    Not a fan of aluminum mirrors btw, so they can stay, lol.
    Jun 23 2011
    Used coil packs are not really worth grabbing. Get the mirrors and put them up for sale. Get the shift knob, wheel, armrest and glovebox.
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    You will need the rear carriers as well as the front, and as mentioned, you will need the rear calipers, fronts are the same, you can use your stock A4 backing plates. And regardless of which rotors your A4 came stock with, the S4 345mm and 300mm are a very nice upgrade.
    See what radio is in it, if it has a RNS-E in it, grab it. Even if you don't use it, someone here will want it.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Sep 27 2008
    Phoenix
    Get the exhaust.
    Jul 31 2017
    Central Florida
    If mirror caps are cheap thats what ill do, armrest and glovebox were a given, lol. Didnt think of shift knob though. Im gonna take the wheel if its in good shape and cheap, not really a big concern. Finally gonna see this thing tmrw. Thanks.
    Jul 31 2017
    Central Florida
    Quote Originally Posted by wootwoot View Post
    Get the exhaust.
    Exhaust doesnt fit.
    Jul 31 2017
    Central Florida
    Quote Originally Posted by mgfranz View Post
    Thanks, like i said i figured out what i need from the brakes, basically everything but lines, grabbing it all, dust shields included. Lol, already asked him about rns-e, no good. Would have had it in the classifieds with the mirror caps monday morning.
    Feb 15 2016
    Cambridge,Ontario
    I think you were referring to the RS4 controller for the fuel pump. I'm not sure its really an upgrade if you are stock every where else. I m not even sure what it does but I do see it mentioned here a lot.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
