Results 1 to 9 of 9
    Junior Member Two Rings reggiesdesign's Avatar
    Sep 13 2017
    Australia
    Sports Differential: System Fault
    A fault appeared tonight "Sports Differential: System Fault" on my 2013 S7. Happened as I was going around a bend at about 30kph. Goes away when switched off but comes back within 60sec of driving - seemingly when I go around a bend again. Just curious if anyone else has had this before and if so what the cause and solution was. Will be taking it into the dealer on Monday as I still have a factory warranty.
    2013 Estoril Blue S7
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Same fault appeared on my car recently. Would not go away even after a few restarts until the car sat overnight. Next day it was gone and did not come back before I had to travel for work. The wife has been driving the car for the last couple of weeks and she hasn't mentioned any lights, but I'm curious as to what triggered the fault in the first place. Will hook up my vagcom when I get home to see what the code says.
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    Sep 13 2017
    Australia
    Let me know if you find anything. I will post an update once the dealer has had a look at it tomorrow.
    Sep 13 2017
    Australia
    All software was updated but didn't solve the issue. Turns out it was the diff oil pump. Awaiting parts to be shipped from Germany. Another 2 weeks without my baby. :(
    Veteran Member Three Rings infinitereality's Avatar
    Jul 05 2017
    Superlite Coupe (SLC) & CRF50
    Louisiana
    Did that fix it? I had the same fault pop up, VCD can't clear it and like you it comes back on after driving the car several hundred feet.
    2018 Camaro ZL1 - Black
    - OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
    - RotoFab, Forgestar CF5V ZLE offsets, SP TB, Eibach Pro, AeroForce Interceptor, Black GT4 Tow Hook
    - Carbon Fiber: Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
    2019 Superlite Coupe: SLC IR/8 - Grigio Telesto
    - 525HP Crate LS3 & Graziano Transaxle
    - 19"/20" Forgestar F14s, Full Carbon Interior, Brembos
    Senior Member Three Rings e36graduate's Avatar
    Jul 15 2009
    Taxachusetts
    Subscribe
    Jul 05 2017
    Louisiana
    I've read it could be the temp sensors on it, but they have to be programmed to be used. I'm unsure why or how, still need to dig into it. I think these are part numbers:
    0BF598081A
    0BF598082A
    Aug 21 2015
    2018 SQ5, 2010 Q5 3.2
    Naperville, IL
    Quote Originally Posted by reggiesdesign View Post
    How many miles on the car? And how frequently has the differential oil been changed? What oil was used?
    Sent from my SM-N950U using Tapatalk
    Jul 05 2017
    Louisiana
    Quote Originally Posted by infinitereality View Post
    After driving the car Sunday thru Wednesday morning, fault came on every time I got in the car....150 or so miles. Since the car had been down for almost 3 weeks for new front control arms, it was due for some fresh gas Wednesday afternoon. Oddly enough, with a full tank I have yet to get the fault to show back up after a few drives and 60 miles. Fingers crossed it just freaked out for a few days, but is odd it went away with a fill up.
