Results 1 to 3 of 3
    Apr 07 2018
    Santa Rosa, CA
    Fuel trims not making any sense! Random misfires. What is the problem??
    Car - 2013 Audi S4 (no cats)
    The car stumbles on acceleration but no misfire codes. Idles rough sometimes. I've replaced all 4 O2 Sensors, MAP sensors, fuel filter, injectors, plugs, crank case valve, fuel control module, and maybe a couple things I haven't thought of.
    No intake or exhaust leaks.
    Can someone take a look at these logs and tell me what the heck the problem might be????? Also my LTFTs rise on acceleration and Bank 1 is usually around 14% when cruising.
    I've taken it everywhere and NO ONE can figure it out.
    Address 01: Engine (8K5 907 551 F)
    20:31:41
    IDE00559 Current of oxygen sensor bank 1 sensor 1 (broadband sensor) 0.967 Lambda / -0.191 mA
    IDE00560-MAS04121 Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage 0.075 V
    IDE00565 Current of oxygen sensor bank 2 sensor 1 (broadband sensor) 1.047 Lambda / 0.145 mA
    IDE00566-MAS04121 Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage 0.875 V
    IDE00597 Long term adaptation of mixture formation bank 1 -0.8 %
    IDE00598 Long term adaptation of mixture formation bank 2 3.1 %
    IDE00604 Short term adaptation of mixture formation bank 1 1.6 %
    IDE00605 Short term adaptation of mixture formation bank 2 -1.6 %
    IDE02119 Long term adaptation of oxygen sensor control: bank 1 48.4 %
    IDE04324 Long term adaptation of oxygen sensor control: bank 2 -28.1 %
    ENG101818 Actual fuel rail pressure 36696 hPa
    ENG99715 Fuel pump: activation 30.048 %
    Apr 07 2018
    Santa Rosa, CA
    Also the car seems to run perfectly after clearing the codes but as soon as the ecu adapts it runs rough and the problems arise
    Apr 05 2016
    Portland, OR
    Geoff
