Results 1 to 4 of 4
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Motul 8100 XCess vs Specific
    Any reason I should go with one vs. the other in my RS5? The Specific is 505.1/502.00 and so is the XCess. The XCess is further certified for Porsche, BMW and Mercedes while Specific isn't. Both cost exactly the same but the XCess mentions modern cars, high power to displacement ratios, etc..probably some marketing hype there but there has to be some difference in the additive package. Both meet VW's standards for the RS5.
    I've already used Specific for about 4K miles and I had to go in for my Audicare service where they obviously switched it back to Castrol. I'll be changing back to Motul in 5k miles and I may do a Blackstone test of the Castrol at that time.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Feb 22 2018
    lawrenceviile ga
    I'd like to know this as well. I currently run liqui Molly and wondering if I should switch to motul.
    Jun 24 2017
    San Antonio, TX
    I went back to Castrol as I had one Audicare left and I can definitely say that Motul makes the engine run more quietly. I'll be trying XCess next change. I go 5K between changes.
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    Quote Originally Posted by Ape Factory View Post
    I run Xcess in my 4.2 S5 religiously. I could not find significant enough difference between Xcess and Specific to justify using specific (if my memory serves correct Specific is a few bucks more expensive). Can confirm the better quality oil affects engine noise, I've run both Castrol and T6 in my car and it got way louder.
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
