Results 1 to 17 of 17
Thread: P0299
    Jan 25 2013
    West Chester PA
    P0299
    So i have a 2013 A4 with 60,000 miles on it and i keep getting a CEL for P0299 boost pressure regulation control range not reached. So i change my DV to the current D revision, changed the N75 valve, replaced the pcv diaphragm and used some maf cleaner on the maf and I'm still getting this CEL. I have also checked for excess waste gate play in the arm and there was no play in the linkage. I have stuck a bore scoop into the cold side of the turbo to look for any obvious damage to the turbo and everything looked ok. Granted that there is no way to know about play in the turbine without pulling the turbo which is kinda my last resort. Any help at this point would be great!
    Feb 02 2017
    Beaverton, OR
    Those are most of the mentioned items to check.
    I kept getting this on my 2013 allroad. They replaced the turborcharger recirculation valve - N249 test drove it and cel was OK for a day. It came back again so it is at the shop and they are replacing the turbo on it. Also note they found the wastegate linkage to be OK. So maybe it is still a bad turbo in your situation as well. Mine is 73,280 miles.
    Jan 25 2013
    West Chester PA
    Thanks Chip_ for your input! I had a feeling that it might be the turbo but before pulling it i wanted some others input as turbos are not cheap...
    Established Member Two Rings Audiosz's Avatar
    Jul 11 2017
    Minnesota
    Quote Originally Posted by chip_ View Post
    That's a shame what did they quote younto replace the turbo
    Sent from my SM-G920V using Audizine mobile app
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Get it replaced by dealership under the extended warranty
    Jan 25 2013
    West Chester PA
    I try to stay away from the stealership if possible. But I thought that the extended warranty was for only the 09-12 A4's. my engine code is CPMA
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Quote Originally Posted by bunna4 View Post
    I think Chip's is a 2013 and he's getting his replaced under warranty. (see his post above)
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    You're in luck! Call Audi and you'll get a free turbo replacement since you're under the 70k mile, 7 year recall. I did mine last year. They also gave me a brand new (at the time) 2017 A4 S line fully loaded as a loaner.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Quote Originally Posted by Nano909 View Post
    I got a new A4 and Q3 as a loaner during my turbo replacement. It was fun rallying those around.
    Jul 25 2016
    California
    Quote Originally Posted by BeerBrent View Post
    I took it to Universal Studios. Lol
    Aug 15 2015
    Prosper, TX
    The original owner I got my A4 from had the turbo swapped out around the same mileage. He also had the pistons, rings and other goodies done under warranty for the oil consumption issue. Basically a brand new engine at 74k miles.
    2009 Audi A4 Quattro / Prestige / Phantom Black Pearl / APR Stage II / GFB DV+
    Established Member Two Rings TJet1.8's Avatar
    Jun 14 2015
    2016 Q5 3.0T
    Ontario, Canada
    Had the same P0299 issue with my A4, all the normal items were checked to be good (Turbo, Intercooler Pipe Clamps, DV, N75, etc...).
    In the end, my tuner found that the rubber seal around the Intake Air Temp sensor was leaking.
    Replacing the IAT sensor is what fixed it for me.
    Add this to the list of things to check for a P0299 code.
    GL.
    • 2017 A4 2.0T - Custom Stg2 ECU & Stg1 TCU Tune (409HP/395TQ - No Meth) from garageautosports.com (thanks Bill!!), CTS CAI + TIP, CTS Intercooler, CTS Charge Pipes, GFB DV+, CTS 3" Test Pipe, CTS 3" Catback, APR Coilpacks, RS3 Plugs, 034Motorsports Trans Mount Insert, Snow Stg2 Water/Meth., Bilstein B8 Performance, H&R Sport.
      2016 Q5 3.0T - Custom Stg1+ Tune (455HP/395TQ) from garageautosports.com (thanks Bill!!!), CTS Supercharger Pulley, 034 Intake Pipe, aFe Dry Filter.
    Jan 25 2013
    West Chester PA
    So i stopped by the dealer today and they are going to take a look at it. They want to replace or add a clip to the waste gate actuator rod and if that doesn't fix the problem the turbo will be covered under warranty.
    Feb 02 2017
    Beaverton, OR
    Yeah mine was replaced under my CPO.
    - - - Updated - - -
    Thats good to know.
    Sep 25 2016
    Philadelphia
    Do you have any upgrades to your car (tune, etc.)?
    Jan 25 2013
    West Chester PA
    No mods or tune to the car.
    Ill keep everyone updated when the car gets dropped off at the dealer on Monday.
    Feb 02 2017
    Beaverton, OR
    Any update on this?
