Results 1 to 8 of 8
Thread: Hole on CVT
    Oct 17 2015
    Fort Lauderdale, FL
    Hole on CVT
    I noticed this hole on the driver's side of the CVT in my 2006 A4 B7.
    Is it supposed to be open like that, or am I missing a plug?
    In case I need a plug, does anyone have a part number?
    Thanks so much!
    PICS:
    Here's the location:
    And close-up:
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    I don't think there is a plug for that area. Doesn't look like anything internal.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Established Member Two Rings DanielP's Avatar
    Dec 08 2016
    Las Vegas
    Your good, mine has it too
    Apr 04 2016
    Kuala Lumpur
    The hole also presence on Tip too..for sure its there for a purpose
    Nov 12 2015
    Orange County
    Looking a pictures of 01j CVT and they all appear to have the same opening with nothing actually there. Looks to be a defacto speed sensor mounting location that's no longer used since the TCM monitors that now?. I didn't see any audi specific part number relating to such a part. It's possible when the casting was designed that LuK (the company Audi worked with to design the CVT) had originally intended it to be a planned location of a speed sensor , that was later changed up by the time the car went into production? In either case, it appears that compartment the opening leads into is sealed off from the rest of the transmission where the CVT fluid resides.
    Here are a picture of a nissan CVT speed sensor, the mounting point is very similar.
    And here's a youtube video of a CVT transmission coming out of an B6 A4, if you look at the 4:23 mark, same opening. Nothing there.
    Sep 02 2008
    Boonies VA
    Don't drop a bolt in that hole. That's no fun.
    White Wagon
    Aug 04 2015
    Kansas City
    Quote Originally Posted by naiku View Post
    When I replaced my coolant flange I dropped a bolt and never found it. Fortunately I had a spare but I was worried that it fell into a transmission hole. I still have no idea where the bolt went.
    Oct 17 2015
    Fort Lauderdale, FL
    Thanks a bunch for all the info guys, much appreciated!!
