Results 1 to 8 of 8
    Jul 29 2015
    Anaheim, California
    Changing front RS5 rotors
    Is it a straight forward job to change rotors (removing pads, caliper bolts and calipers and slidng rotors off and on) or is there any trick involved in the procedure? Thanks.
    Mar 15 2013
    Waipahu, Hawaii
    Pretty straight forward. After removing and hanging the caliper out of the way, you'll need a T30 torx bit to remove the set screw. My rotors were frozen on the hub so I used a dead blow hammer to unseat the rotor. You may need some "angry" love taps to unseat them, lol.
    Jul 29 2015
    Anaheim, California
    Thank you for your quick response!
    Quote Originally Posted by RSenvy808 View Post
    Senior Member Three Rings MME1122's Avatar
    Mar 26 2016
    2011 Jeep Liberty
    Having just done my brakes, I'd recommend some penetrating oil too. And a wire wheel or sand paper to clean up the hubs before putting the new discs on.
    Alternative to a hammer would be to use some bolts like this: https://www.youtube.com/watch?v=Ep7NdZMn1mk
    I should've either gotten a bigger hammer, or just used the bolt method. Using the bolt method you may be able to have the rotors turned and either reuse them, or maybe sell them. Those RS5 rotors are expensive lol so I'd recommend that.
    Jul 29 2015
    Anaheim, California
    Thank you.
    Quote Originally Posted by MME1122 View Post
    Jul 03 2007
    2017 Highlander Hybrid
    Saw that you're just doing the fronts. If you change your mind, for the rears, you need to put the e-brake in service mode, needs a VAG-COM. Watch the video at the bottom of this page.
    http://wiki.ross-tech.com/wiki/index..._Parking_Brake
    I had a hard time getting a firm pedal after replacing pads/rotors, ended up having to bleed a couple times, so I'd have some fluid and bleeding kit on hand in case you need it.
    His: 2016 Golf R
    Hers: 2017 Highlander Hybrid
    Past: Audi 90q | A4 | S4 | RS5; VW Mk1 Scirocco | Mk2 GTI | Mk4 GTI VR6 | Mk5 R32 | Touareg TDI; '65 Dart /6
    Jul 29 2015
    Anaheim, California
    Thanks. I guess since my car is both CPO and AudiCare, I did not think I would need to buy a VAGCOM. Maybe I can borrow one when time comes for the rears.
    Quote Originally Posted by wago View Post
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    Quote Originally Posted by Alexandros View Post
    or a very affordable option - get the Carista app and a bluetooth OBD-II dongle. That will give you the ability release the rear parking brake, check and reset codes, reset major maintenance intervals, and do some minor customizations.
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
