Results 1 to 4 of 4
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    P2007 after PCV replacement...
    So I replaced my PCV yesterday and had to take the driver side intake manifold off to pull it out. I thought I assembled everything right but now I am getting P2007 error, which is stuck flapper on the intake manifold. Sounds like the most likely culprit is vacuum leak somewhere so I will inspect all the lines once the car cools down. Has anyone experienced any other causes of this P2007 error or fault?
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    When you installed your butterfly flaps
    Did you push the flaps down abit with your fingers before dropping it down and bolting it up?
    If not the flaps cant open
    They hit the intake plates that are in the ports causing that code you have.
    Sent from my SM-G950W using Audizine mobile app
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Yup this ^
    Pull off charger and make sure your flaps are below the metal bar.
    Sent from my MI MIX using Tapatalk
    Mar 05 2012
    Omaha, Nebraska
    What mattt said, however... I actually had a grain of walnut get into my solenoid that controls the vacuum for the flappers. So, if both flaps move on/off vacuum (you can pop the line off really easy running) then you’d avoid pulling the charger if you have a simple issue up top.
    2010 Audi S4 DSG Meteor Gray; Daily; USP intake/Miltek non-res W/Black Oval tips; Dual Pulley (3.139) GIAC/DSG Tune/APR CPS 11.884 @ 115.9
    Oldies-10 Blue A4 Stock,00 Nogaro Blue 6MT, 04 Moro Blue S4 6MT, 00 A4 Avant w/tip
