Results 1 to 40 of 46
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    6MT Allroad shifting “thud” sound?
    Life happened and my project is now my daily. 2003 2.7T Allroad with a manual transmission and 166,000 miles. No service records on transmission or clutch. I think it is safe to assume the clutch has been addressed at this point, maybe not.
    When I engage or disengage the clutch on upshifts I hear and also feel a “thud” from the drivetrain. I don’t feel it in my foot I feel it in my seat. I’ve tried all different ways of transitioning throttle with clutch engagement and it’s almost always there. Downshifts to a stop are 99% “thud” free and I can rev match just fine. Downshifts for accelerating are 50/50 on the “thud”. My logical mind says “It has 166,000 miles and the bushing and mounts are all tired and shot, shit is moving too much.”
    Anyway, heater core was clogged really badly so I replaced it. I didn’t realize it at the time, but I messed up the brake switch and had to get a new one. Is there potential I did the same with my clutch switch, it was removed also? It disengages cruise control just fine, but I’ve found a couple posts about that switch causing issues on other members’ cars, hence my allusion the rev matching on downshifts and shift noise. Any guidance or experience is much appreciated.
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    probably trans mounts and/or diff mount maybe even motor mounts or snub mount
    and if you ever find yourself on the central Oregon coast hit me up we can talk allroads! haha I'm the only euro/audi/allroad/anything besides lifted trucks and Honda guy out here.
    I also have access to a lift we can check all those mounts
    May 20 2010
    ^These. I used to get a thud and all my rear diff mounts were toast. Replaced with the Apikol set. Pricey but worth it, I think.
    The giubos on my driveshaft were also worn, contributing to some motion there.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Oct 02 2013
    05 allroad FBP 6mt, 06 VW Passat Komfort, 08 VW Touareg V8 FSI
    pennsylvania
    x3. These guys got you on the right track.
    Apr 24 2011
    the giubos? is that a typo or something I'm not familiar with?
    not poking fun, just curious
    Sep 11 2009
    NE
    The main culprit is rear differential mount IMHO, that one allows the rear differential to hit the metal brace and is right under the rear bench. Besides that, the tranny and engine mounts are probably also ready to be replaced but these usually don't make thud sounds when they go.
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    Quote Originally Posted by m_haiser View Post
    It's a flex joint
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Sep 11 2009
    NE
    Apikol absolutely not worth it , this is after 4 years or so:
    You want to buy OE bushing 4B3599381 (you can get it from fcp groton), fill it with polyurethane 3M window weld to add stiffness to rubber and press it into factory bracket. It will cost literally few bucks and will far outlast apikol with similar stiffness.
    May 20 2010
    Quote Originally Posted by julex View Post
    We'll see. YMMV. No problems yet on year 1.
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    can you pour a new bushing? mine is apikol too. this pic scares me lol
    Feb 05 2007
    Portland, OR
    Thanks for all the responses. You guys are rad! I was fearing something transmission related and getting nervous. Looks like I’ve got more mounts to add to the ever growing list of parts and mods.
    Hahahaha, I can only imagine. I’ve spent plenty of time over there. I appreciate the invite man!
    Apr 24 2011
    Quote Originally Posted by ShelbyM3 View Post
    No problem! It would be nice to hang out and talk cars haha
    Sent from my Z917VL using Tapatalk
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    Feb 05 2007
    Portland, OR
    Any of you have any experience with the AWE Drive Train Stabilizer?
    https://www.uspmotorsports.com/Audi-...nsmission.html
    Sep 11 2009
    NE
    A big skip, completely unnecessary. It will add a lot of noise and vibrations. Get a set of good transmission mounts first and if you think you still have movement then address engine mount and look at snub as well.
    I would recommend 034 street version because they're a solid chunk of galvanized rubber and their bushing is captured in the rubber as well, which is the main reason why OEM style mounts are superior to poly one if made with stiffer rubber that is. The weak point and reason why poly mounts are crap is because they are always made with free-floating bushing which with time destroys the poly from inside out due to inherent rubbing between housing-poly-bushing interface.
    More bad news to apikol crowd, these are my apikol transmission mounts after about tops 3 years. My apikols' poly got squished with time leaving a lot of slack in the mount which resulted in a lot of movement and jerking/thudding of the whole drivetrain. Basically the moral of my story is: don't buy anything made entirely of polyurethane (and yes, these are fully "compressed" and assembled mounts...):
    Sep 11 2009
    NE
    Quote Originally Posted by alien_brain View Post
    Sure you could, I don't see why not. I went back to stock bracket + new Lamfoeder bushing which I filled with poly to fill all the stock voids in the rubber. Once that settled, I pressed the bushing in which really compressed the poly inside so it is like a solid mount now but has the bushing captured in the rubber. If you look at my apikol mount that failed, it is clear that poly basically got smeared around by the combined weight of differential and heat generated by friction between sleeve and poly itself.
    Feb 05 2007
    Portland, OR
    Thank you sir. Appreciate the insight. I’ve already got 034 engine mounts and transmission mounts in my wish list.
    May 09 2012
    Virginia
    Julex, do you think your setup from a power standpoint had anything to do with the wear on those mounts? Your turbos are pretty small...
    Sep 11 2009
    NE
    Quote Originally Posted by jbain2 View Post
    Rear differential maybe because there is a lot of twisting there when full torque hits but then the mount is marketed as racing mount so why would it fail in this way due to torque? .
    Tranny shouldn't. The tranny mounts are simply squished due to weight of transmission riding on them all the time. There is no weird wear on them like on the rear differential mount... just evident compression and deformation.
    Jun 07 2005
    Shepherdstown, WV
    Agree on diff mounts as likely cause. The parts car for my 6mt swap had urethane filled stock ones that I first had installed when swapping diffs. I was having some driveshaft alignment issues so I swapped my original mounts back in thinking maybe the filled ones were not lining up the diff right... Had a clunk ever since.
    Removing them did eliminate some road noise though it seemed and was hoping I could just keep it like this.. I already reluctantly have street density engine and trans mounts since this is my quiet car and the one we use for road trips. But I'll be getting new busings and filling them like julex mentioned. Just with something not as rock hard as the previous owner used.
    Feb 05 2007
    Portland, OR
    Finally got around to checking on mounts and FCP says that part number only fits 2001-2002 and I have a 2003. Anyone have advice on this? I know APB vs BEL makes a difference and I’m a BEL.
    May 09 2012
    Virginia
    What parts are you looking to replace again? I just did all the rear diff mount stuff on my 03 and can post the part numbers if that’s what you are looking for?
    Jun 07 2005
    Shepherdstown, WV
    For both 01 and 03 I checked:
    rear two bushings 4B3 599 257 A
    whole carrier with bushing 4B3 599 285 A
    front bushing 4B3 599 381
    carrier with bushing 4B3 599 125
    All the same not sure why someone is saying 01-02 only.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Sep 11 2009
    NE
    Fits 01-05:
    Feb 05 2007
    Portland, OR
    Thank you guys!
    Any need to replace the rear mounts while I’m at it? I haven’t visually inspected them yet, but I’m doing engine, tranny, and front diff already.
    Sep 11 2009
    NE
    Thank you guys!
    Mine were pristine at 15y mark. They see very little stress. It is the front one that gets all the action.
    Feb 05 2007
    Portland, OR
    Thank you julex, you’ve been extremely helpful. All of you have. I’m excited to add to the ever growing pile of parts, hahahahaha.
    May 16 2008
    South Texas
    People assume that stiffer performance mounts last longer which is incorrect. Urethane isn't as robust as rubber.
    Feb 05 2007
    Portland, OR
    Roger that. I got factory replacements.
    Nov 02 2008
    A mess.
    Grapevine,TX.
    I used Apikol rear bushings inserted into the front housing, they were perfect fit. Cost $60 for 2 sets, so even if they go bad after several years, I have a spare set. Then again, I doubt I will put more than 300hp out of my car, so they may hold. I also replaced the center support bearing/bushing at the same time as it was also bad.
    2019 VW Tiguan 4mo SE. Orange, stock for now.
    Former: 91 SHO, 83 5000S Turbo, 78 Supra, 86 Golf, 69 Chevelle SS, 2 Taurus wagons. 72 Olds Toronado
    2001 B5 Passat 4Mo Wagon, 6sp/1.8T swap. Sold.
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by PZ. View Post
    Is the driveshaft support bearing a total pain to replace? I’ve been mulling that around as I wait for life to give me a much needed wrench break.
    Senior Member Three Rings Grainreaper's Avatar
    Nov 19 2016
    Lake in the Hills, Illinois
    Wrench break???? You do know you are in the C5 forum right? 😂😂
    May 20 2010
    I gave it a whirl and couldn't get it undone, but might've been approaching it now. I heard 034 did one a long ways back but had to build a custom jig to hold the damn thing in order to try. I am thinking of trying Colorado Driveshaft to see what they can do for me. Emailing them doesn't seem to work though.
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by Grainreaper View Post
    I need time to wrench. I am fully aware of how I am now my Allroad’s bitch haha.
    Feb 05 2007
    Portland, OR
    That’s what I though, total pain. But it can be done. I guess I’ll start small and see how things go from there.
    Jun 07 2005
    Shepherdstown, WV
    When I rebuilt mine I couldn't get the bolt off (it had some marks and looks like someone tried before) so I just ended up impact chiseling the head off, extracting what was left of the bolt and now it is a stud and nut.
    I've got a brand new allroad bearing if anyone needs one.
    Feb 05 2007
    Portland, OR
    Diff mount is out and completely torn on the lower half. Ding ding ding. Now to install the new one. Shop press for this bad boy?
    I finally have my project back! My better half got her new car, finally. Used 2018 SE Alltrack 6MT with 2,200 miles for $23,000! I think we scored.
    Feb 05 2007
    Portland, OR
    Long story short, according to the machine shop that’s the wrong part. 70/1000 too big and he’s afraid to press it in and break the support bracket. Called up Matrix Integrated and they don’t list a part# for a manual Allroad rear diff mount. It’s “grayed out” and he can’t see a part number. Hit up Audi Wilsonville and the parts manager says there’s only one part# listed for that and I have it.
    I ended up ordering the entire support with the bushing in already, 1 of 3 in North America, and I’m hoping this solves my problem. Damn! Wish me luck!
    Established Member Two Rings superdlux's Avatar
    Dec 24 2009
    Part number?
    Oct 30 2009
    Miami, FL
    The diff bodies are the same between manual and auto, so I can't see why the bushing would be different. I would've tried wire wheeling and sanding the inside of the mount bracket to get rid of corrosion and pressing in the new mount, that's usually all it takes.
    Sent from my MI 5 using Tapatalk
    2018 S5 Coupe - stock for now
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by superdlux View Post
    Part number?
    Part# 4B3-599-381 for the bushing itself and that’s the only part number listed with Audi. I find it weird that Matrix couldn’t tell me a part number because it was grayed out.
    Part# 4B3-599-125 for the whole shebang with the bushing installed.
