Results 1 to 10 of 10
    Oct 02 2006
    Wadsworth,OH
    New! ECS Remote Exhaust Cutouts | Engage LOUD and quiet modes
    Power and noise when you want it, comfort and quiet when you need....
    The ECS Vacuum Actuated Exhaust Cutout
    The option between open and closed exhaust at the flip of a switch
    Click HERE for your Exhaust Cutouts
    Free up horsepower easily without sacrificing comfort with the ECS Vacuum Actuated Exhaust Cutouts!
    A simple modification that allows you to flip between the factory exhaust routing through the full system or dumped out the open valve when you need extra performance.
    Since the vacuum-actuated valve is not electronic, it will not stick or burn out, meaning you will enjoy this effective modification for a long time without worry.
    No welding required, instant power, and a fraction the cost of a full exhaust system makes this the perfect upgrade for your German performance car.
    https://www.youtube.com/watch?v=b0ZRpVNSaGs
    Click HERE for your super loud button
    Click HERE to dump your exhaust
    Click HERE for your ECS Remote Exhaust Cutouts
    Click HERE for Vacuum Actuated Exhaust Cutouts
    Click HERE to Click HERE
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Love the idea! Kind of pricey though, and doesn't match to factory exhaust tubing size.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Hmm $400 and maybe 4hp. I guess if your goal is to be the loudest it’s a great bargain.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jun 17 2016
    king of prussia
    I have been waiting for this!!!!
    I’d love to see this in action, before I switch from awe touring
    Dec 06 2017
    Marietta, GA
    Yea we need some operation and sound clips
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Where would this cutout be installed on a B8.5? Before or after the mid-resonator? Also, our cars have 2 pipes all the way from the from the engine to the tips. I assume this piggy-backs just one of them?
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Veteran Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    It's going to sound like complete dog sh*t when these are open for literally very little gain.
    2018 Glacier White RS3 - Unitronic Stage 2 (E85) ECU, Stage 2 TCU
    2014 Estoril Blue S4 (DSG) - Sold (11.2@121mph 93 octane)
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by Dannydyn View Post
    i think they would need to be before the rear mufflers, dumped in the wheel wells? i can't think of where else they would fit.
    @ECS - how does the vacuum actuation work? pardon my ignorance
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Oct 02 2006
    Wadsworth,OH
    Many of my guys are running 2 of them, as for where to put them it's up to you, I've seen them as far forward as well... right off the headers and as far back as right before the rear cans.
    KRp220 no problem it's so complicated it's simple. The valves natural position is closed, vacuum is supplied via the vac lines on the motor and controlled to the valve by a pressure valve. When vacuum is appiled to the cutout valve it's pulled open giving you an exhaust dump. Basics of how they install can be found HERE.
    Feb 01 2018
    Coquitlam, BC, CANADA
    Bump! Has anyone installed these?
    Also curious about just installing ONE of them lol. Can't think of a reason it would harm anything and it would be "half as loud" ?
