Results 1 to 4 of 4
    Senior Member Three Rings tsbpenguin's Avatar
    Mar 15 2008
    03 RS6 x2, 04 Allroad 6mt k04, 07 Tundra, 92 Legacy
    303 (CO)
    Another 2.7t - no start
    2001 a6 2.7t 6mt, 170k miles. Got the car from a guy who had it parked for the last 5 years, but it was running when he parked it (he said only issue was he thought the cat was bad).
    Changed all the fluids, and new battery, no start (not getting fuel). Put in a used fuel tank and brand new pump. Now it gets fuel and spark but no start. No engine codes on the VAG, registering rpms during cranking so can't be crank sensor. Haven't checked compression yet, but it sounds like it's getting compression.*
    Clogged filter or injectors? Any ideas are appreciated.
    Feb 07 2008
    The boonies, near Seattle
    If its been parked for 5 years compression is probably too low. Other possibility is bad gas.
    -dre
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    id change out the fuel filter as well
    easy $20 fix
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Mar 15 2008
    303 (CO)
    Why would compression be too low from sitting in a garage? Can't be bad gas since we swapped out the old tank (with the gas in it) and replaced the fuel pump.
    Quote Originally Posted by PaperToast View Post
    easy $20 fix
    Yeah I'm going to do that next along with a compression test.
