Results 1 to 8 of 8
    Senior Member Three Rings WewannaB7's Avatar
    Dec 07 2014
    07 Porsche Carrera S Cabriolet, 12 M-Benz ML350
    New Jersey
    What’s this that fell off my B7?...
    Was driving home from work today, and hear a pop from under the center of the car. I thought my car’s tires kicked up a rock or something, but when I got home, I saw this hanging down from a pipe in the center of my car. Pulled it off and it looks like a heat shield or something. What is this, and does this mean my exhaust will have a hole in it soon?...no extra noise from car yet.
    08 2.0T Quattro SE, APR Stage 1 - 93 Oct
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    That’s the flex pipe off of your exhaust. Pretty integral for the exhaust to not hang off the downpipe. You probably want to get that repaired immediately.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Dec 07 2014
    New Jersey
    Quote Originally Posted by james12lucy View Post
    Crap. Ok, thanks. Can any basic muffler shop take care of it?
    Jul 04 2015
    Toronto Ontario
    Shouldn’t be an issue. The probably have to remove your downpipe and front section of your exhaust to do it, but shouldn’t have an issue.
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Not sure how rusted your exhaust system is, they could weld a new flex pipe on no problem if there is some exhaust left
    Dec 07 2014
    New Jersey
    Ok, thanks guys! I’ll get it checked out.
    Dec 05 2016
    miami FL
    probelm seeing image. can you check and fix please
    Dec 07 2014
    New Jersey
    Quote Originally Posted by ahotboy15 View Post
    Image shows up fine for me. Google exhaust flex pipe, and you can see the metal fiber weave. This is what fell off.
