Results 1 to 11 of 11
    Mar 25 2018
    Dripping noise while turbo kicks in?
    When i press down on the gas and the turbo kicks in, I hear a sound of water dripping inside the car. Any thoughts?
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    Overflowed the blinker fluid
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Mar 25 2018
    Quote Originally Posted by Tiggy View Post
    How do i remove some? And do you mean turn signal fluid?
    Jun 07 2016
    Portland, Oregon
    Quote Originally Posted by adamleaf8601 View Post
    Theres no way
    Mar 25 2018
    Would this have anything to do with the turbo?
    Established Member Two Rings JS4Avant's Avatar
    Dec 01 2014
    2004 dodge 2500
    Battle Ground, Washington
    Mar 25 2018
    Bump
    Mar 25 2018
    Anyone have any ideas?
    Jan 03 2013
    Baltimore
    Sounds like you have air in the coolant system. Did you have the coolant recently serviced? Air is trapped somewhere, usually within the heater core. You need to burp/bleed the coolant system.
    Sent from my Pixel using Tapatalk
    Mar 25 2018
    Quote Originally Posted by elscotto80 View Post
    Interesting. I do have a rare issue with intermittent heat. Basically sometimes the heat doesn’t reach optimal temperatures. I wonder if this could be related? How hard / expensive is it to bleed the coolant system?
