Originally Posted by
JBAeroEngineer
This makes no sense, you need a stiffer spring for the heavier motor. If you put this on an A4 you'll be sitting higher than stock. Sure, it'll fit though.
If it makes no sense, let me try to explain. But first do you know the weight difference across these 3 engines you mentioned?
To address your comment about A4 being higher than stock is absurd. A4 stock suspension sits higher than all S4, S5, and RS5 that’s unless A4 is an Sline where it shares the same suspension as base non EDS S4. Furthermore almost all aftermarket is selling the same suspension for the platform regardless on the engine and transmission configuration. For example bilstein pss10 are the same part number across the whole platform. Same goes to the lowering springs. I even provided the picture showing that RS5 suspension is no higher on my personal s4. Please, you are engineer, research the market before you try to ruin my for sale post.
Sent from my iPhone using
Audizine
