Results 1 to 4 of 4
Thread: IE rods
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    Used IE rods look spun. Need advice
    Hi guys,
    The rod down there has a very odd looking mark under the bearing. Do you think it spun the bearing?
    Would you use this on your car and why?
    I plan on using a K04 on my car btw.
    Thanks for any help
    [IMG][/IMG]
    [IMG][/IMG]
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Crank journal bearing surface looks to be a little corroded as if the OCI was too long. It does not look like it spun. Wrist pin bearing looks OK but hard to tell from photo. Measure to see if it meets roundness and diameter specs.
    Mar 24 2013
    Oakdale, CT
    Clean it up and run it. It's fine. Every used rod I've pulled apart had bearing imprints like that.
    -Adam
    Sep 07 2015
    Romania
    Cheers gents.
    -Alex-
