Results 1 to 3 of 3
    Active Member Two Rings boostinavants's Avatar
    Jan 24 2010
    98 a4 avant workhorse
    walnutport
    1.8T Build Engine
    Full bottom end build, brand new never ran. Rings need to be gapped, lost the original set?misplaced them so upgraded to the newer JE PROSEAL set p/n matched for my pistons accordingly. all parts ready to assemble and have yourself a fully built 1.8t bottom end for a really small fraction of the price to build a motor.
    Specs:
    058 ATW block
    IE Rods with tool steel wrist pins (proper mm size)
    JE 8.5:1 comp ratio 82mm pistons
    ARP main stud kit
    ARP head stud kit (proper 11mm)
    ARP 625 rod bolts
    Calico Rod bearings
    Calico Main bearings
    Balanced and spec'd Crankshaft
    powder coated white valve cover
    extra parts:
    all stock parts from tear down
    bnib febi oil pump
    bnib merle oil cooler
    bnib head gasket
    bnib main seal (front)
    bnib dipstick tube and new stick
    bnib iwis cam tensioner chain
    cam and crank seals
    few S&M valves not a whole set tho.
    block is hot tanked, decked, bored and honed to all parts said above, intermediate shaft balanced, crankshaft balanced, everything spec'd for clearances and blueprinted. I have all the receipts for all parts and work preformed. I've chosen to do a full vehicle build and changed my power train choice so i really just don't have a need to finish this or any of the parts. do yourself a favor and save huge $$$$.
    feel free to contact me for any more info or pics.
    price firm at $1900
    [IMG][/IMG]
    Apr 12 2018
    Kitchener, Ontario, Canada
    I'm very interested! I come down to states all the time and will be down in roughly a week or 2. can you PM and we'll get in touch. if you can shoot me some pics and all is good I'll take it all from you. Just let me know!
    I would PM you but I honestly just signed up to be able to send this message and I'm not sure how to PM
    edit: NVM I figured it out, PM sent!.
    Jan 24 2010
    walnutport
    PM sent
