Results 1 to 21 of 21
    Established Member Two Rings Mr_Hooper's Avatar
    Jun 04 2016
    Littleton, CO
    UniConnect & Parallels on a Mac
    I did a search & didn't find any substantial evidence of use cases, but.....
    Has anyone had success using a Mac/Parallels set up with the UniTronic Uniconnect cable? UniTronic couldn't recommend this approach but mentioned that others have successfully flashed/re-flashed/logged using a VM or running Parallels on a Mac.
    I'd love to exhaust this approach before running over to Best Buy & picking up a PC laptop for a couple hundred bucks.
    2021 S4 Premium Plus Quantum Grey
    SOLD:2016 A6 Moonlight Blue
    SOLD:2013 S4 Premium Plus Estoril Blue
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Is a tablet a possibility? I am heading toward Uniconnect for my K04 tune, but only have a mac as well. I run my VCDS on a Windows 10 tablet that I won in a charity event a couple of years ago without an issue, so I have been curious if it would suffice for the Uniconnect load.
    Here's the link: https://www.walmart.com/ip/NuVision-...&wl13=&veh=sem
    EDIT: I don't think this tablet would work, since it only has 2GB of RAM sorry
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Jun 04 2016
    Littleton, CO
    Quote Originally Posted by bakedziti View Post
    UniTronic recommends, at a minimum, a processor speed of 1.5 GHz OR 4GB of RAM or higher. Granted, I'm assuming you could use the tablet but at a slower rate (not sure if it will crash) & assuming you can use the micro USB to USB adapater.
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Mr_Hooper View Post
    Yeah, you're right and must have quoted me before I edited my post. Hopefully someone will chime in with some Mac success, so I don't have to use my work laptop.
    °2011 A4 | 6MT
    Oct 20 2008
    Denver
    I can't speak on this issue regarding Uniconnect, but when I ran parallels on my MacBook pro for VCDS, I would almost always be unable to read, scan, etc. I tried installing, reinstalling, update drivers and everything for parallels and windows but no dice.
    I ended up using bootcamp to run either Windows or Mac separately, worked like a charm since .
    May 06 2015
    Minnesota
    FWIW I know a lot of the guys (including myself) who run the EPL tune use HP Stream 8 tablets that you can buy refurbished from Walmart for roughly $75. I also use the micro USB to USB adapter (OTG). I ended up going that route because all I have at home are Apple products. Sure would be nice if the flash at home tuners figured out how to be Apple iOS compatible............
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    ive been trying to partition my macbook pro to use bootcamp but cant seem to get it to work!
    from my understand it will work without issue in bootcamp/windows10
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by AudiTFSI3o3 View Post
    That's good to know. It would be awesome if the tune-from-home companies could ensure that their flash software worked well with Windows running via Bootcamp on Mac.
    SOLD 2015 Daytona Gray S4
    Senior Member Three Rings tominabox1's Avatar
    Nov 08 2017
    DFW
    Quote Originally Posted by SteveYem View Post
    There's no reason it wouldn't. Its the same as running windows on any other computer.
    2014 A4 Quattro // Sport Package, Black Optics, Bang and Olufsen
    IE Stage 2, CR-15 Strut Brace, USP High Flow Cat, Spulen turbo inlet pipe, aFe filter
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    With Bootcamp, using Windows on a Mac should work 100%. I would go this route if flashing the actual ECU.
    If you’re just using VCDs, you can get by using a VM. (Virtual machine) I personally use VirtualBox and have never had an issue with a Windows 10 guest OS. Just be sure that you enable the USB cable from the devices list so it gets pass through to the VM. I imagine using Parallels is very similar.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by tominabox1 View Post
    In theory I agree, but I do not believe EPL will vouch for it. So if I go that route and run into problems, after their telling me it's not guaranteed to work, I'm out on my own. I cannot speak for Unitronic as I have no experience with them.
    I know, a $100 tablet takes care of the issue, and I spent that much on alcohol last weekend, but I guess I'm just stubborn.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    It really depends on the hardware, usually the pass through usb device is emulated and thus have a different driver. It might or might not work. Your safest bet is to run boot camp so everything is running under native driver. I'm an engineer working in virtual machine team in one of the big cloud company:)
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Jun 04 2016
    Littleton, CO
    Hear, hear!
    Veteran Member Three Rings Spoorguy's Avatar
    Mar 26 2015
    Rheinland Pfalz, Germany
    I ran boot camp on my MacBook. Only issue is how much storage you got in order to partition. Ran good too along with VCDS as well. I’m going to just buy a used chrome book or cheap one and call it good.
    2002 B5 S4 (Sedan), GIAC stage 1, vinyl wrapped dark gloss grey - SOLD
    2010 B8 S4 Unitronic DP | AWE Tuning- Touring w/ Non Res DPs | Merc Racing HX | Airlift 3P - SOLD
    Veteran Member Four Rings GrkA4's Avatar
    Jan 14 2005
    B8 S4, MkV R32, B6 A4 (gone)
    Newtown, PA
    I tried to use VCDS using VMware Fusion and it did not work. Always ran into connectivity issues. Ended up getting a cheap ass Dell and it works perfectly. Would definitely skip any sort of Virtualization app on top of Mac OS.
    B8 S4 Sprint Blue - UNITRONIC Stage 2+ & S-Tronic Flash, Roc-Euro Intake, Magnaflow Exhaust w/ non-resonated downpipes, Eurocode Sway Bars & AK, 034 Trans Mount
    MkV DBM R32 - VF Engineering Intake, Magnaflow Exhaust, HPA Dogbone Mount, Neuspeed RSB and End Links, H&R Springs, RNS-510
    CB Tuning
    Unitronic
    Nov 08 2017
    DFW
    Quote Originally Posted by Spoorguy View Post
    Chrome books can't run windows apps...
    Jul 14 2013
    British Columbia, Canada
    I use vmware and run my bootcamp partition that way unless I need to specifically be booted to Windows. No problems with VCDS.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Aug 20 2015
    I run Parrallels and it works fine, both VCDS and UniConnect+.
    Mar 26 2015
    Hmm...you’re right.
    Oct 01 2017
    Flashed my car the other day using parallels with uniconnect+
    https://www.instagram.com/p/BhNgshdj...ken-by=s4_tony
    May 09 2012
    Virginia
    I ran windows on boot camp for a while. It works without issue. I got tired of doing that and broke down and bought an inexpensive windows based laptop from Best Buy for $200. It remains my dedicated unit for car stuff.
