Results 1 to 4 of 4
    Feb 13 2018
    Porsche 944 Kalahari Beige
    New Hampshire
    Help Deciding What Spacers to get
    Hey all I have a A4 B7 S-line with Enkei Raijin 18x8 45mm offset wheels for summer tires (michelin pilot super sport) on and have stock 17x7.5 45mm offset for winter tires (NOKIAN HAKKAPELIITTA R2)
    I am installing ST Coilovers that i purchased in the fall and i'm looking for the wheels to look flush to the fenders on front and rear with the spacers i end up getting. Any help is appreciated. If you need anymore info just ask. Thanks!
    Jun 27 2017
    Montreal, Canada
    Quote Originally Posted by bryanpolanski View Post
    I would suggest 10mm front and 15mm rear. This is based on the ECS Flush fit kit that I have on my car and it looks good without rubbing.
    https://www.ecstuning.com/b-assemble...10425ecs01kt3/
    Aug 09 2012
    Sylvania OH
    Easiest way to do this is to measure the distance of you current setup to the wheel well and then purchase spacers based on this measurement. If you are looking to do it for the two wheel sizes, measure your current set up, and compare to your other setup using willtheyfit.com to put you somewhere in the middle.
    Jun 20 2017
    Reading
    I have 10mm for my fronts and I have yet to put them on because with a Koni coilover setup they will definitely rub. I'll probably sell them.
