Results 1 to 13 of 13
    Oct 26 2016
    Air ride error after Eurocode install
    I just did front and rear sways and endlinks. I also added the AK. Right after installing it and setting the car down I got an error saying the air ride and the cruise control doesn’t work. The car was on jack stands for a week. Any advice?
    2013 S6
    Mods: 20" factory wheels powder coated black, 20% ceramic tinted windows, 20% tinted tail lights, 17mm lower via vag com, Pirelli Soto Zero 3 Snow Tires, Pirelli P Sero Summer tires, Weather tech floor mats, Ala Kreuz, Excort Passport Redline hard wired
    Options: comfort seats in black, night vision, stop/start cruise control, HUD, winter package, bang and olufsen
    Junior Member Two Rings
    Aug 31 2017
    2014 RS7 Daytona Matte, 2016 Tacoma TRD Off-Road, 2017 Acura MDX
    Portland, OR
    Do you have the CETE module? I’m having the same issue after putting on my summer tires (yes I put the suspension in service mode before lifting it).
    Veteran Member Three Rings arrivalanche's Avatar
    Jun 08 2014
    Placentia, CA
    Did you change the setting to tire change first in the MMI? Id scan it either way and if its something stupid, just clear it.
    -AARON-
    2018 S4 Black Optic
    2017 S6 Black Optic - Sold
    2016 S6 Black Optic - Sold
    2014 A6 3.0T Black Optic - Sold
    2014 S4 3.0T Black Optic - Sold
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Oct 26 2016
    I did put it in service mode. Nothing comes up on my regular OBD reader. I’ll try vag com tonight.
    2013 S6
    Jun 08 2014
    Placentia, CA
    So you have warnings coming up on the dash but nothing shows up when you scan it?? That's very weird. I've noticed that doing nearly anything on this car can throw a code just out of self preservation Im guessing. Some go away after a few drives, others you just have to clear.
    -AARON-
    2018 S4 Black Optic
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Jun 08 2014
    Placentia, CA
    I do feel like I have to say this more to everyone on this forum, but I think its a BS move to put Eurocode in the title of your thread. You installed the parts and had the problem. Its not an issue the parts nor did they install them. Its not fair to a business when people post stuff like that because something went wrong in their installation totally unrelated to the product. I'm sure you're not blaming them, but these threads are here forever and titles like that are misleading.
    -AARON-
    2018 S4 Black Optic
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Did you check those ride height sensors at each wheel? Might have popped a link off.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    I don't see the OP blaming Eurocode, only that the name was included for specificity. Any manufacturer name could be included w/o causing harm. OP is just looking for a solution.
    No different when someone installs ______ brand of exhaust system and gets a CEL. Shouldn't happen, but it does and its usually not the exhaust system involved.
    Jun 08 2014
    Placentia, CA
    Quote Originally Posted by bpd View Post
    You're kind of proving my point with the comparisons. The brand/product had nothing to do with an air suspension error because they are completely unrelated. Its 100% the installation (no knock to the OP). Im not here to start drama. There are just a few threads in here where people blame brands for every one of their issues with the car but 9/10 its not the product.
    -AARON-
    2018 S4 Black Optic
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Aug 31 2017
    Portland, OR
    Quote Originally Posted by tenspeed View Post
    This is actually a helpful reply. Do you have a picture of the sensor? I can’t find it on chilton manual...
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Quote Originally Posted by Odontoid View Post
    This isn't the exact sensor from an S/RS (i stole it from google), but gives you an idea of what to look for. It looks really similar and is near each end link.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Dec 12 2011
    Honeoye NY
    That's a good typical picture from ericw. The links typically go from the lower rear control arms to a sensor on the body.
    Sometimes the arms break when people try to install lowering links. If I had an S6/7, I would try making my own links from R/C car and airplace parts.
    Jun 30 2016
    NNJ
    I bet you broke one of the level sensors. I had a customer do that once in the exact same circumstance (car was on jackstands for a week or so while wheels were getting powdercoated). You either popped a link off or broke the arm.
