Results 1 to 4 of 4
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Any way to disable Cold Diagnostics for LED retros?
    I threw in an entire set of LEDs (brakes, signals, sidemarkers, etc) and I'm not getting bulb-out errors. However, I'm getting a very cop car-esque flash sequence every time I turn the car on as it goes through the cold diagnostic sequence. I know that with newer VAG products long-coding can be used to disable the "Cold Diagnostic" feature that runs when the car is turned on. Is anyone familiar with any way to disable it in the B6?
    I tried adding a resistor to one of the sidemarkers without any effect. Does anyone know of any coding/wiring change we can do to ditch the diagnostic sequence?
    Video of the light show... And a quick demo of how stinkin' bright these things are.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I get the same thing. I just deal with it. Only happens during startup. Not worried about it.
    USP CLUB MEMBER #34
    Fry Sauce, UT
    I've been trying to figure out if the pulses during startup are a full 12 volts but I don't think my multimeter is fast enough. I'm wondering if something like a capacitor could be used to take the pulses like an accumulator/shock-absorber.
    If the pulses were less than 12v, maybe something could be rigged to step the voltage down a bit. The LEDs I have only need 9v to operate so if the overall voltage was stepped down, maybe the flashes wouldn't occur.
    Any electrical engineers out there?
    - Steve
    NKAWTG
    Jan 06 2009
    The LED high beams I have do the same behavior. It's annoying
    B6 2.7t BEL tuned by Bische
    B7 2.0t
