So, I have a pretty consistent clunk I keep hearing and feeling from the rear diff area, particularly on/off throttle. I’ve even got it coming off the brake pedal in traffic as well.
Mounts all look good (carrier/front diff/trans). I even put 034 inserts in today to see if that may help.
I know the GIAC TCU tune doesn’t help as it is much rougher with engagement than factory tune. However, the only thing I can think is going on at this point is excessive lash in the driveline, internally in the differential.
Or that I’m just completely being tricked and the motor mounts are just super shot, as I will get a clunk here or there backing out and moving at odd angles.
Has anyone else experienced anything similar to this and had a good fix?
