Either coincidentally (sure) or because something was knocked astray when the brakes were flushed a few weeks ago, I have gotten a bogus SHUT ENGINE, CHECK COOLANT LEVEL warning on the dash eight times now. The first time, the day after that service.
VCDS tells me the coolant is a steady 99C, which seems fine, and the dash gauge is sleeping in the usual "halfway" position. And that bottle is absolutely full with the original red coolant which Audi presumably topped up during this most recent service, or in the past.
But as I look at the coolant bottle, I see two small black rubber hoses on the top, presumably the radiator connection and the drain, and one heavy wrapped hose connected under the bottle, where it mounts to the frame. That hose is hot, so I'm guessing it is also a coolant hose, not just a fat harness.
But I don't see anything like a simple level sensor, a float perhaps? Something that might simply have come out of position or failed, and that can be easily tested and replaced to get rid of the bogus "I'm sorry Dave, the core is melting down now." warnings.
Anyone ever met that cooking level sensor before? I'm afraid to ask, is it perhaps located not on the bottle but reading the level from elsewhere??
