Results 1 to 1 of 1
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Achtuning | Announcing the new Hartmann FF-003-CG flow formed wheel!
    The Hartmann FF-003 wheel is the first flow formed wheel that Hartmann has produced, available in an 18x8.5" sizing and weighing as little as 19.8 Lbs in the ET45 offset it will improve both aesthetics and performance!
    In typical Hartmann fashion the wheel is 66.56 mm hubcentric (57.1 mm hub rings are included for vehicles with 57.1 mm hubs) and designed to use the OEM Audi R13 ball seat lug bolts, it also accepts OEM Audi centercap part # 4B0 601 170 7ZJ.
    Flow forming is a hybrid process between a low pressure cast wheel and a forged wheel. Flow forming starts with a low pressure casting which is then spun while steel rollers "form" the barrel of the wheel. This process benefits the strength and durability of the barrel while simultaneously reducing the weight of the wheel in the most beneficial area for performance (far from the center of rotation).
    Hartmann has chosen a unique new finish for the new flow formed wheel. The Carbon Grey finish starts out with a black basecoat followed by a matte silver topcoat. The black basecoat tints the topcoat to give a dark silvery finish which is quite dynamic depending on the lighting. A matte clearcoat is then applied for protection.
    Currently available sizing is 18x8.5" in an ET35 or ET45 offset. The ET35 and ET45 will fit the D2 chassis A8 and S8, the D3 A8 V8 can use the ET35 offset however the W12 / S8 brakes are too large. The D4 A8 / S8 brakes are also a bit too big for this wheel.
    Orders can be placed over the phone at 1-877-722-4886 weekdays from 9-6 PST or online:
    hartmann-ff-003-cg-18x8-5-et35-wheel-for-audi-and-volkswagen/
