Results 1 to 11 of 11
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Turn Signals Not Flashing But Hazards Work
    My turn signals are turning on as solid lights, not flashing. If I activate the hazard switch they flash as normal.
    Is this an issue with the flasher relay/hazard switch or the stalk on the steering wheel?
    My gut says the former but wanted opinions before I order a new flasher relay.
    Sent from my XT1254 using Audizine mobile app
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    You could try spraying some electrical cleaner into where the turn signal stock goes into the steering colum while you articulate the stock.
    Crud gets trapped up in there and messes with the contacts.
    Worked on my girlfriends c5 suprisingly
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    The hazard switch is the turn signal relay and the contacts are sticking. Just replace it.
    Aug 24 2014
    Newport Beach, CA
    Replace it with only the Audi/VW part, DO NOT use Vaico or any other brand unless you want your car to burn to the ground.
    2024 M3 Comp xDrive
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Hazard switch like others said. I’ve gone through 2 so far.
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Quote Originally Posted by christianb5s4 View Post
    Glad I asked, thanks all, I'll order it tonight.
    Aug 24 2014
    Newport Beach, CA
    I did the DIY electrical contact fix on my original turn signal/hazard switch, lasted a year before it stopped working again. You can do the fix but it's easier and longer lasting to get a new one honestly.
    As an aside. I mistakenly bought a Vaico hazard switch instead of an Audi part in one of my many huge ECS orders, I pulled into my garage one night and the hazards turned on out of nowhere. Started smelling burning and ripped the thing out and it was literally seconds away from burning it was so hot. It was not even 2 weeks old.
    2024 M3 Comp xDrive
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Is that RELAY under the knee bolster (Drivers side) or up and left of the glove box????
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Quote Originally Posted by LJS View Post
    Both hazard and turn signal relays are built into a plastic box that is attached to the hazard button behind the trim.
    Nov 05 2009
    Denver
    Quote Originally Posted by Alex1188 View Post
    Exactly, it's the hazard switch
    Apr 08 2013
    Connecticut
    THANKS!
