Results 1 to 14 of 14
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Aftermarket Fuel Pressure Regulator?
    Hey all.
    So, as you may know, I’m upgrading one of my B7s. As part of the upgrade path, I’ve been reconstructing the fuel system to do away with the OEM tank and LPFP setup.
    To this point, I’ve put together a trunk mounted, 17 gallon fuel cell, twin Walbro 485 pumps, AEM 7 micron fuel filter, and Torqbyte CM5-LT and PM3 to control it. It’ll retain OEM control over both pumps, and will prime when the door opens, etc.
    The issue I’m struggling with, is if I’ll really need an inline fuel pressure regulator? I know the OEM filter has an inbuilt 6BAR regulator, but I’ve done away with the OEM filter. Since the HPFP has a fuel pressure regulator to sort out anything over 165BAR, the injectors will never see pulses associated with port injectors. My question is this; will possible low pressure pulses adversely effect my HPFP? I know it’ll sort out the fuel and return it, but I’m worried about the fuel between the LPFP and HPFP.
    Please feel free to chime in. Thanks AZ.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Mar 24 2013
    Oakdale, CT
    The stock lpfp is controlled via PWM to regulate pressure. The regulator in the fuel filter is more of a backup overpressure relief. You should be fine if your walbros retain PWM control, but if you wanted to put in a FPR inline, it wouldn't hurt anything.
    -Adam
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    In my opinion I don't think we even need a fuel pressure regulator on the low side. As you said, the HPFP system regulates it itself and the low side will never get above 50bar anyways. I think it's more of a safety thing by the factory. As above said, if you got PWM, you should be fine.
    *Ninja edit* I wouldn't tune to 10bar. Might throw codes
    Sent from my ONEPLUS A5000 using Audizine mobile app
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Mar 24 2013
    Oakdale, CT
    I gather from your OP that you're adding port injection? If so, the low side for the port injection and hpfp should be maintained separate. The large pressure changes in the low side will make it a nightmare to try to tune the port injectors. You just need to run one pump for each half.
    -Adam
    Jul 04 2015
    Toronto Ontario
    Thanks for the heads up, fellas. I will be retaining PWM control with the PM3, so I’ll pass on the fuel pressure regulator.
    Adam, not going port injection this year, but didn’t want to rule it out. I’m running both pumps to ensure there is zero starvation issues. Both of those fuel baskets have ball valves and will be connected via a -8 line to share fuel when pulling G’s. It was a cheaper and simpler solution to adding a secondary or cell mounted surge tank. Also, it keeps the pumps submerged, which will keep them running more efficiently.
    If I decide to add port, I’ll add a fuel pressure regulator, but I doubt that’ll be this year. I’ve already sourced a 034 Motorsports EFI controller, but am not sure if I should pull the trigger. Ultimately, I think dual fueling is a great idea, but the car is an endurance car, so efficiency is also a premium. Also, building the head makes more sense before I add a third fuel source (I’ll be spraying meth).
    Thanks again, fellas.
    Mar 24 2013
    Oakdale, CT
    In that case, run it without an FPR unless it starts to give you issues.My only question I guess is why so much low pressure fueling when you are severely limited by output of S3 injectors?
    -Adam
    Jul 04 2015
    Toronto Ontario
    That’s a solid question. Redundancy. I’m okay with Over fueling and not starving for fuel in a high G corners. And I’m totally OK if I drop one pump well racing.
    Mar 24 2013
    Oakdale, CT
    Fair enough.
    -Adam
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    You’re going to throw codes for the low pressure side exceeding the pressure range it’s setup for. You can change the range with winols, not sure if maestro gives you that option though.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by derrek View Post
    Thanks, I hadn’t actually thought about that. I will look into changing it. But if it was a cold and doesn’t go into limp mode, I really don’t care. It’s not like the car is without 1 million codes anyways, I have eradicated it most of the CANBUS system.
    Jul 23 2010
    arizona
    Quote Originally Posted by james12lucy View Post
    It messes something up, don’t remember right now as I haven’t done very much b7 stuff this year. It was a problem though.
    Mar 24 2013
    Oakdale, CT
    IIRC, you can change that in maestro.
    -Adam
    Jul 04 2015
    Toronto Ontario
    Awesome. So what do I do? Just log at WOT and set min/max?
    Established Member Two Rings Joshlc1988's Avatar
    Jun 19 2017
    06 a4 s line 6mt, 95 s10 zr2
    Clifton forge virginia
    I don't think your going to get by without a regulator. I would think you would have to modify every map that sees a pwm change.correct me if I'm wrong but my understanding is the pwm signal grounds the pump, in turn giving it 100% power for that pulse. Those walbros have around a 120 psi max each. So their gonna try to push over 8 bar every time the signal is sent.
    Example: say 30% duty is 30 pulses every 60 seconds. So the pumps are gonna go wide open 30 times every 60 seconds. That's over 8 bar pulsing up to the hpfp. I would think that it would be hard to tune for that.
