    Dec 28 2017
    Poland
    Boiling coolant, desk temp 90def, no radiator fan switched on
    My coolant got BOILED with visible small smoke, reached the cap (full reservoir) and leaked away from occurred crack in the reservoir...
    The temp. On desk 90 deg, the fan did not turn on, outside temp. around 15deg and it happened when I stopped... I did not even drive fast
    What could happen?
    My Audi drives me crazy last days ...
    Wysłane z mojego SM-G950F przy użyciu Tapatalka
    Dec 28 2017
    Poland
    Radiator fans are OK
    Where to find the coolant temp sensor and how to test it?
    Wysłane z mojego SM-T280 przy użyciu Tapatalka
    Active Member Two Rings bwhite2332's Avatar
    Nov 23 2017
    Schuylkill Haven
    Coolant temp sensor is at the bottom of the expansion tank. If it comes out, so will all of your coolant
    Dec 28 2017
    Poland
    I found the issue... The cap (!)
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    That will do it, it’s a pressurised system so with a failed cap the water will be allowed to boil where it would normally boil at a higher temperature.
