Results 1 to 4 of 4
Thread: motor mounts
    Sep 12 2010
    New York, New York
    motor mounts
    Just had motor mounts replaced on 2012 A4 Avant at 63000 miles. Dealer mechanic claims they were torn. Cars runs better with turbo lag reduced and some vibration gone. Looked at new mounts online and very little rubber is exposed. So how does mechanic know they are torn? How long should they last?
    Established Member Two Rings Zingrox's Avatar
    Sep 03 2016
    2010 A4 currently being built
    Pennsylvania
    They are visibly torn, they are hollow inside and tear quite often. Normally rips under the metal slug the bolt goes through
    If you Google it you'll find pictures
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by Zingrox View Post
    they are fluid filled.
    Sep 03 2016
    Pennsylvania
    Yes that makes the rubber hollow to be filled with fluid. It isn't a solid piece of rubber is my meaning, of course
