Relevant excerpt from
togwt1980.blogspot.com:
Cyanoacrylate (Superglue)
Ethyl cyanoacrylate (ECA) C5H5NO2- Loctite® Super Glue is virtually 100% ECA. Cyanoacrylate is an acrylic resin that is moisture cured (anionic polymerization) and forms a strong bond almost instantly.
One of the easiest ways to remove Cyanoacrylate (Superglue) adhesive is to use Acetone nail polish remover. Acetone dissolves these types of adhesives, but use caution using acetone to clean Cyanoacrylate adhesive that is stuck to plastic or polymer clear coat; and avoid hard rubbing Acetone can also cause damage to plastic surfaces or even melt smaller pieces (test on an inconspicuous area first).
Most hobby shops and some hardware stores carry some sort of Cyanoacrylate remover. In fact, one of the most popular products is actually branded: Super Glue Remover (check to see if they contain Acetone).
