Originally Posted by
SkiahMutt
Hey guys, finally got my RNS-E installed and wired in my 2002 A6. I'm looking at the various bluetooth options for the RNS-E, and I'm having a hard time figuring out which one to get. Is there a way I can add an adapter that will let me make and recieve calls from the RNS-E like a factory kit, AND let me stream music?
I could be wrong but I think that the factory bluetooth never did music. Here are our aftermarket options.
http://enfigcarstereo.com/IPOD_AUDI_A4_07.html
1. AUX only
http://enfigcarstereo.com/ENFIG_AI2_AUX.html
2.AUX + Bluetooth Music WITHOUT song up & down controls from radio
https://enfigcarstereo.com/ENFIG_AI2_BTA_AUX.html
3. iPhone& Ipod through 30pin + AUX
http://enfigcarstereo.com/DENSION_GW1LAI2.html iPod + AUX
4. iPhone& iPod through USB + AUX
http://enfigcarstereo.com/ENFIG_AI2_IPDU_AUX.html iPod via USB + AUX
5. iPhone& iPod through 30pin with song info in the cluster + Aux
http://enfigcarstereo.com/DENSION_GW17AC1.html iPod + Aux with song info in the cluster
Adding this allows you to swap the 30pin cable that comes with the unit above for a female USB for apple products.
http://enfigcarstereo.com/DENSION_LIA1GW0.html
6. USB for memory sticks + Bluetooth with option for iPod and aux
http://enfigcarstereo.com/DENSION_GBL3AI2.html USB + Bluetooth with option for iPod and aux
You can add a 30 pin ipod cable to get charging and a little better audio.
http://enfigcarstereo.com/DENSION_IPO5DC9_NC.html
Adding this allows you to add a female USB for apple products.
Adding this allows you to connect an aux to the unit above.
http://enfigcarstereo.com/DENSION_CABL_AUX.html
This is the same as above but with a female 3.5mm aux and a USB for charging.
https://enfigcarstereo.com/ENFIG_CABL_AUX35F_USBCH.html
For this last option the vehicle must have rolling steering wheel controls.
Or if it has the 3 on each side the bottom two must be left and right arrows.
7. USB for Memory sticks and apple products. Bluetooth with song and call information (car must be programmed for call info).
http://enfigcarstereo.com/DENSION_GWP1AC1.html.
It is strongly recommended that you get the item below with the item above. It adds the aux and reset button. So when the unit needs a reboot you don’t have to pull the radio.
http://enfigcarstereo.com/DENSION_EXT1CP2.html
Keys to remove the radio
http://enfigcarstereo.com/ENFIG_RRK4...OOLS_KEYS.html
Grounding tool
http://enfigcarstereo.com/POSI_EX_150B.html
