Results 1 to 22 of 22
    Apr 04 2018
    '15 tacoma
    Burbank California
    Angry Help in an impossible situation... Destroyed my 3.0t and engine torn apart.
    TLDR:B8 s4 with blown engine after unitronic+high miles. Looking for options.
    Hello. I do not know who checks these forums, but I really hope someone can offer advice.
    Lots of information, but I will try to present it logically.
    The car is a phantom black b8 2010 s4, with every package I can think of.
    I have RSM9 wheels, BBS wheels, and audi 19's for it.
    Recently it was tuned with unitronic. I had the confidence to get it done after
    replacing the mechatronics unit. I knew that an agressive tune wouldnt be good for a car with 120,000 miles, but the
    unit malfuctioned and replacing it was needed.
    The tune, unitronic stage 1+ TCU and stage 1 ECU, was great.
    Between my lack of catalytic converters, air intake, and AWE Track edition exhaust, I believe the tune did really make the car
    much faster and more responsive.
    However, about a month after the tune, I had problems. The engine had just been fully serviced, but already was suffering,
    partly from one mechanic who worked on it forgetting to, and in two occasions breaking or leaving unplugged the connectors to the coil packs. Those connectors came of while driving, forcing the car into limp mode.
    That issue aside, this is where the car dies
    I was driving 45mph and the car suddenly bogs. Power ceases and the DSG shifts down until the tach goes seemingly negative, and I could hear no ping or noise, just a stop. The engine seized up, and would not turn at all.
    I got it towed to my house, and tried to start it, no dice.
    Tried a few other things, then thought to see if i could rotate the crank at all...
    Nothing, completely and udderly stuck, as it it was welded together
    Well, my only valuable asset was stuck and worthless, so I put all of my cash into getting it ripped apart quick.
    With all the wiring harnesses, tubing, etc, out of the bay the engine was taken out along with the dsg. Nothing seemed wrong in the supercharger, the heads, valvetrain, etc. The gore was in the crank case and the oil pan was cringeworthy.
    Metal shavings the size of dimes were in my oil pan. It was brutal... The first crankshaft bearing must have seized, spun in its place until it put the crank out of place, and then the crank's weighted side struck and ate into the side of the case. At least... that is what I figure. Regardless, the bottom end of the engine is useless.
    And along with it, the vehicle is useless, and torn apart.
    So here is why I am posting this:
    What should I do?
    Is there any way out? Would anyone want a destroyed and expensive to fix pos.... or could I fix it.
    I really want it fixed, and I especially wouldnt want to see this amazing machine meet such a terrible fate.
    If there is any way I can silver lining this with a new engine or even some crazy swap.... I just need a way to repair this vehicle. In the meantime, I have a mode of transportation... but it isnt anything like the s4.
    Thank you for your time.
    Oct 14 2012
    Empty...for now...
    SE PA
    Sorry to hear of your misfortune. Maybe this would work? https://www.audizine.com/forum/showt...te-engine-1500
    SOLD 2015 Daytona Gray S4
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by GLIS4 View Post
    What should I do?
    Is there any way out? Would anyone want a destroyed and expensive to fix pos.... or could I fix it. I really want it fixed, and I especially wouldnt want to see this amazing machine meet such a terrible fate.
    Ouch! Sorry to hear of the issues! Engine failure on these cars, especially in the way you described, is exceptionally rare!
    Anyway, you'd get pennies on the dollar for the car if you were to try and sell in it's current state. The best bet is to purchase a used engine and install. Used 3.0Ts are plentiful for ~ $3-4k, and better deals can be found.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    Get a used engine.
    Have to ask. Why the hell didn't the mechanic drain the oil with and check for shavings before pulling everything off?
    2013 S4 S-tronic - 3.47 PR // EPL DP ECU/TCU tune // PLM hx // APR intake // Jokerz Blower // Headers // Ice box // iABED TB // Autotech HPFP // RS7 LPFP
    11.186 @ 123.35
    1993 URS4 - GT3071R - EFI Express Tuned - Gutted
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    I may be wrong but i saw a 3.0 engine in the classfields the other day for $1500?
    Think its from an a6, but its the same engine?
    Apr 04 2018
    '15 tacoma
    Burbank California
    I was asking the same thing. No clue.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    thats some really bad luck, typically these motors will last a very long time.
    get a good longblock in that car and enjoy the Unitronic tune :)
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Apr 04 2012
    MSP
    Darn man!
    As mentioned before - quite rare to hear of. As mentioned as well - just get a used motor and throw it in there.
    Good luck with the repair!
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    Lower end failure like that is very rare. When was the last oil change, who did it?
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Just for your peace of mind, your failure likely had zero to do with tuning it unitronic. Something else caused this. Very sorry to hear what happened though. Good luck!
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Contact Skokan Audi Recyclers in New York. They have tons of Audi parts. A friend got a like new A4 engine from them a couple of years ago and was very satisfied. Either call or just fill out the online parts query on their website.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Senior Member Two Rings Tom Sawyer's Avatar
    Apr 01 2007
    TN
    Quote Originally Posted by LYKUNO View Post
    +1 on Shokan, great to work with; I bought an oil cooler for my RS6 when the drivetrain was pulled for a torque converter replacement. That was a project, I suspect your S4 engine transplant would be less... involved and certainly less expensive.
    Good luck with it!
    2020 SQ5 Prestige, Quantum Gray, S Package, Nappa, BO, DA
    Gone but not forgotten: 2000 B5 S4, 2004 B6 S4, 2003 RS6, 2016 S4 P+ DSG
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    That sucks dude.
    I just went through the same thing with my engine.
    Save yourself time and hassle and just buy a used engine.
    Feel free to PM me with what 3.0T engines will work and what parts you need to swap from your old engine if you get a b8.5 engine or a7 etc..
    Shop around for the engine and you might find a good deal.
    I scored a great deal on low kms engine from a forum member today.
    Sent from my SM-G950W using Audizine mobile app
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Bummer man, sucks!! S4matty was yours a bearing issue too? I know you were pushing hard.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by RWD2quattro View Post
    I cracked #5 piston.
    Aug 17 2017
    2001 Audi TTQC 225, 2003 VW GTI 20thAE, 2016 SQ5
    Atlanta, GA
    Quote Originally Posted by s4matty View Post
    Top ring land?
    Apr 04 2018
    '15 tacoma
    Burbank California
    So an update:
    Messaged someone with a long block for 1400 but there is no proof of it being functional and mileage worries me.
    As much as I wish I was, I am not an audi technician and have no clue how to put this engine in.
    Cats are completely blown thru, but no CEL ever came on and it never caused the car to misbehave.
    Only things that did go wrong were the mechatronics unit, while was replaced at 125 or so, never malfunctioned after.
    and the coil pack connected were coming off towrd the end, due to one shop taking a less-than-careful tactic on disassembly.
    Mar 03 2009
    Cape Cod, MA
    If you’re paying a mechanic to install an engine I think you’d be better off buying a complete used motor instead of a mystery long block. The additional labor of using a long block will probably offset the difference in cost vs a complete motor.
    11.186 @ 123.35
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by CollecTTor View Post
    Top ring land?
    I still have to tear it apart
    But from putting a scope In the cylinder
    I can see a crack on the piston from the edge near the cylinder wall to near the center of the top of piston.
    Aug 15 2015
    2 feet
    Niagara canada
    Also OP
    If you end up buying a b8.5/a6/a7/sq5 engine for your b8
    Send me a PM and I'll let you know all the parts that need to be swapped over from your b8 engine.
    Might save you some labor costs at the shop knowing what parts need to change when both engines are out.
    I've done 8 swaps on these cars and 7 of them have been b8.5 into b8.
    Cheerz
    Matt
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Check Phoenix craigslist there is a B8 motor for sale on there. No SC but long block.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    He's in Vermont. If that engine in the classifieds from CT mentioned early in the thread is still there that sounds like the ticket to me.
