Results 1 to 3 of 3
    Apr 12 2016
    Minneapolis MN
    Clicking from stop
    Hey guys,
    I have a 2013 s5, and over the winter it started a very quiet clicking when pulling out of my parking spot at work (forward with slight rt turn)
    As the winter has tried to wind down (we are getting snow again today lol) the clicking as gotten at least a little worse, not terrible but worse...
    I assumed it was a CV going bad and crawled under it this afternoon... All 8 CVs are dry and don't appear to have cracks... I don't see any geese spray or wetness on or around any of the CVs...
    The clicking sounds just like a CV going bad, speed of clicking increases with speed, but goes away once I am up to maybe 10mph... The only other symptoms I have noticed, not sure if it's related, is that at highway speed I get what sounds like a tire our of balance (kind of like a tire wobbling at high-speed sound, tread changing pitch on the road) this was first noticed after getting new tires and I have had the dealer rebalance the tires 3 times with no change...
    Has anyone had something similar?
    I don't have access to a lift so it is harder to look at it, but with a jack and flashlight I don't see anything....
    Is it possible for a CV to go bad without the boot going? If so what's the best way to diagnose that...
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    I just went through this on my 13 S5. The CV joints are probably damaged by piss poor grease from the OEM. I posted on this last week, OEM axle grease poured out like motor oil, axles were clicking exactly as you described. I’ll send a link to my post
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Oct 08 2012
    Read this post, this is probably your issue also. I found that the clicking will only get worse, and eventually I started to feel binding at low speed and sharp turns. New axles fixed all, and more.
    https://www.audizine.com/forum/showt...ht=drive+axles
