Results 1 to 8 of 8
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    Different plug gap values in same engine at same time ??
    I'd like to know if more than one person has ever had different plug gaps in their engine at the same time, on purpose not from wear?
    Something to the effect of.. having a few at .026 but still seeing activity/correction on a couple cyl's so gapping only those down to .025
    What's your experience with this? Did you end up later just gapping them all down to the same size? Just seems weird having diff burn rates due to diff gaps.
    I'm asking this because my mechanic said neither he nor some person at giac has heard of having dif gaps at same time.
    PS There is absolutely nothing on the internet about this, some interesting side gap stuff, spent well over an hour looking, nor on here except a thread where I'd asked the question w/o much traction...would really like to hear if more people than just the one person that answered in DP thread have done this since my mechanic saying what he said and finding nothing on the net.
    Thanks,
    Bill
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Like adapting gap to, for example, timing pull values on individual cylinders?
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I think the specs are .30, although I remember reading someone suggest that .28 might work better.
    Jan 09 2008
    Winnipeg
    I am currently running different gaps on one bank trying to determine some knock pull I was seeing. I cleaned and gapped the 3 plugs to .026. I saw knock pull decrease so I think it's just time for new plugs and coils...which I have waiting to go in.
    Normally I would make them all the same if it weren't for testing.
    Feb 17 2017
    Tempe, Arizona
    Quote Originally Posted by theweebabyseamus View Post
    I'm seeing up to -6 & -7s on cyl 3,4,6 using IGA_AD_1_KNK_* the other three are at 0's, so I'm wondering if it's best practice to adjust just those w/activity or make them all .025
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Try it and see. I do not see how it can hurt the motor at all.
    Back in the day we used to index spark plugs to orientate them to the cumbustion chamber. This meant some plugs extended further into the cylinder than others. You would think that would change the performance in other ways, or at least I did. When your looking for every ounce of hp out of a motor restricted by class rules you try anything.
    Looking forward to seeing what your logs show.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    the goal of gapping each cylinder separetely is to make sure there is no knock in any cylinders which should - more timing/more power
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Feb 17 2017
    Tempe, Arizona
    Thanks everybody for the input...looks like I will just adjust the 3,4,6 which show activity.
    What's interesting is that according to firing order 1-4-3-6-2-5 the cyl's showing activity are all in a row. Hopefully more top end after adjusting those three
