Hello,
Question on timing belt change. We were changing TB, water pump, thermostat, pulleys etc on 05 A4 3.0l engine. We locked down camshaft with locking tool, we followed all torque specs and procedures from Bentley book and blauparts instructions. To clarify, it was our first TB change on Audi. We did not lock down crankshaft bolt for two reasons. One, the area of where bolt was said to be located from the book was vague, and there were two bolts In That location. And two, we then saw and read about many change outs on Audi A4 3.0 that didn’t use that and only used the camshaft tool, and everything came out fine.
Ok, so we proceeeded that way, but once we had eveything torqued back down and while watching the camshaft bever move at all. We installed the crankshaft pulley with those two marks and the eighth bolts. The timing mark on the pulley and block were now off (back to the left) by about 1-2 mm at the most. It was ever so slight. Now it was perfectly on when we started originally and locked down the camshaft. While the locks were still in place on the camshaft, I moved the crankshaft clockwise back to the exact mark. It barely moved to get it there.
Question is, is there going to be a problem or is there any play whatsoever with this. I can’t imagine with all the TB changes on these cars and with only using the camshaft locking tool, That others haven’t experienced a ever so slight movement with the crankshaft and timing marks. The only I can think that had the torque to move it were the camshaft bolts as they called for 74 ft lbs.
Thoughts. And thanks for them.
