Results 1 to 20 of 20
    Senior Member Two Rings BWilson's Avatar
    May 15 2017
    Central NJ
    Want To Replace A6 Rear Diffuser with S6 Diffuser ?
    I have used the Forum Search and haven't found exactly what I'm looking for. I want to replace my A6 rear diffuser valance with a S6. I also want to find just the rear dual tip exhaust for a S6 or aftermarket exhaust. Hopefully I'm using the correct terminology for the parts I want to replace. I like the look of the dual tip exhaust compared to the A6 single tip exhaust. Maybe later in the future I may change the entire exhaust system. Please post any pictures, instructions or advise to achieve this look. Thanks in advance for any and all help.
    2014 A6 Premium Plus
    19" HRE FF01
    H&R Sport Springs
    EPL Stage 2 and TCU tune - SC Pulley -
    Injen CAI
    AWE Touring Exhaust
    4.11 sec. - 0-60 mph
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Buy the diffuser then take it to a muffler shop and tell them you want quad tips to align with the new diffuser.
    S6 exhaust won't fit an A6 without the shop basically rebuilding it anyway so don't waste your time looking for one.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    Someone posted something just like you wanted with tips like this that fit perfectly in the S6 diffuser. You will have to search for that thread. Or it could be at the other Audi forum.
    https://www.ebay.com/itm/Dual-3-5-Ou...RYelGk&vxp=mtr
    May 15 2017
    Central NJ
    Quote Originally Posted by bpd View Post
    I found this...would this work? Can I cut the rear dual tip muffler and weld it the the A6 exhaust? I will not use the tips that come with the diffuser.
    http://www.ebay.com/itm/S6-Style-Rea...53.m1438.l2649
    19" HRE FF01
    H&R Sport Springs
    Injen CAI
    AWE Touring Exhaust
    Mar 29 2014
    Hampshire, UK
    This is my A7 (now sold). I fitted the AWE Quad Tip exhaust system, and changed the valence to the S7 one. I also carbon wrapped the valence as it was a bit boring
    You can do the same thing to the A6 using the S6 valence. The AWE Quad for A6 or A7 are very similar.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    May 15 2017
    Central NJ
    Quote Originally Posted by RAF_S7 View Post
    That's exactly what I want to do. Now I have to find the parts that will fit correctly.
    19" HRE FF01
    H&R Sport Springs
    Injen CAI
    AWE Touring Exhaust
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    You have premium plus option which is non Sline, eBay should have plenty options.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    I recently performed this conversion and wrote down my thoughts below for those looking to do the same. (Note - this is for C7.5)
    So I've been wanting to replace my stock diffuser with an S or RS option since I bought the car. Unfortunately, all the RS options I found were not going to fit without extensive modification. So I figured an S6 diffuser would be the path of least resistance. I found various different options, but I really wanted the diffuser in gloss black (unlike the matte black OEM) to match my gloss black optics trim pieces. I found the perfect diffuser on Aliexpress (links below). This diffuser has nuanced differences, such as more "aggressive" fins, which I love. I also bought a dual exhaust tip set that slips in just like the stock non-S tips.
    Diffuser fitment was perfect. Seriously, not a single hiccup. The driver's side exhaust tips went in without issues, but the passenger side did not and took some work to get it right (and it arrived with a loose tip that I took to a welder to re-attach). Overall, I'm incredibly happy with how it turned out. Huge improvement over the boring stock diffuser.
    Diffuser:
    https://www.aliexpress.com/item/4000...55084c4d48flCY
    Exhaust tips:
    BEFORE:
    AFTER:
    Here are some comparison photos between this diffuser and OEM. Note the fins and the obvious finish difference.
    Aug 24 2014
    Newport Beach, CA
    Looks amazing Jonny, seems like a super straightforward swap. Glad you posted because there aren't as many pictures of this mod on a C7.5!
    2024 M3 Comp xDrive
    Oct 26 2014
    California
    Quote Originally Posted by christianb5s4 View Post
    Thanks! Yeah, I wanted to make sure I provided some references because I'm sure I'm not the only who's thought of doing this swap!
    Veteran Member Three Rings coop3422's Avatar
    Jan 11 2019
    Calgary
    Quote Originally Posted by JonnyBravo! View Post
    Those look fantastic. I wasn't even thinking AlliExpress because I didn't know how the fitment would be. Is your car an S-Line? It looks like that might make finding something for my C7 harder.
    Oct 26 2014
    California
    Quote Originally Posted by coop3422 View Post
    Yep, S-line. I'm pretty sure I've seen some options for non-S on AliExpress and eBay.
    Some more photos (with a clean car this time!).
    Jan 11 2019
    Calgary
    That looks great, think I'll go this route. What colour is that? Looks awesome, I thought it was just black in the prior pics.
    Oct 26 2014
    California
    The car? Or the diffuser? Car is Moonlight Blue Metallic.
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    I have RS7 mufflers on my A6 and I still have the stock A6 bumper :)
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Established Member Two Rings slumber12's Avatar
    Jul 18 2014
    Audi Q5 3.0T
    West Burbs of CHI
    Do you have another link for the diffuser? I can’t get that one to work.
    Veteran Member Three Rings Speedooooo's Avatar
    Sep 13 2015
    Cincinnati, OH
    Link worked for me.
    Did you pay $500+ for it? It's $300 + $227 for shipping. I like the diffuser more than the MD one but can't justify the almost $300 cost increase.
    2018 Glacier White A6 3.0T | Driver Assistance | Sport | Black Optics
    2016 Mythos Black Q5 3.0T SOLD
    May 10 2019
    Haverhill MA
    StoneCarbon2009 now stocks this rear diffuser for much less than AliExpress. The tips pictured are not the same as what Johnny has, but those can be sourced from AliExpress.
    StoneCarbon link here:
    https://www.ebay.com/itm/S6-Style-Bl...gAAOSwnv9e4uDb
    Jul 30 2013
    Colorado
    I replaced mine on my A6 sline, with an OEM S6 diffuser purchased from a member. Fake AliExpress Akrapovic quad tips on my 3.0t Magnaflow exhaust. Pretty simple and inexpensive project all in all. Paid around $175 for the diffuser shipped to me. $188 for the tips shipped. Had my Indy do the work for around $200. Please excuse the filthy car pic.
    Oct 26 2014
    California
    Quote Originally Posted by SilverGSX99 View Post
    That's a pretty good deal. Just FYI, you will most likely need to do some cutting and possibly welding with those tips since our muffler tips are pinched almost immediately after the muffler.
