Results 1 to 15 of 15
    Aug 16 2017
    Killeen, Tx
    B8 S5 plug and play oil catch can kit
    I have for sale an oil catch can kit for a b8 s5. It's full plug and play with oem connectors. $300 shipped. Works very well, it will definitely help with carbon build up by not allowing the blowby to reenter the manifold and end up on the back of the valves.
    Aug 16 2017
    Killeen, Tx
    Installed
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    Install directions included? Is this the Black Forest one? Is it easy access to un-screw the can?
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    Is this the Black Forest Industries kit?
    Aug 16 2017
    Killeen, Tx
    It's not black forest. I made it. It is very simple to install, it has the oem connectors on it. You take out 1 screw by the headlight and put the bracket there and screw the screw back in. That's it.
    - - - Updated - - -
    And yes you can unscrew the can without removing it for easy changes.
    Veteran Member Four Rings jschrauwen's Avatar
    Aug 08 2013
    08 R8 TT, 08 A5 3.2 QTip, 90 300ZX TT 572whp 590wtq, Ducati TT2
    Frankford, Ontario, Canada
    Can you or will you be making ones for the 3.2L V6?
    2008 A5|Ice Silver|3.2 QTip|Premium Pkg|Technology Pkg|B&O & JL10W0-4 sub|15/20mm spacers|HID Fogs|Ext. & Int. LED's|RS5 grill|AWE/K&N Intake|Quad tipped OEM mufflers|CF Mirrors, Spoiler & Diffuser|Facelift Ecode Tail lights|CR-15 Strut Bar|Ecode headlights|Alu Kreuz|ProdigyWerks 6pot 2pc 356mm front 350mm 2pc rear BBK|Eibach springs
    2008 R8|Ice Silver|R-Tronic|Huffman TT Conversion|Focal/Mosconi stereo upgrade|H&R Coilovers|HRE wheels
    Aug 16 2017
    Killeen, Tx
    I could but I don't have access to a 3.2.
    Dec 26 2008
    STL
    That looks sharp, good job bud! I don't know about reducing carbon on valves, not much will help lol.
    Aug 16 2017
    Killeen, Tx
    Do you see how much it caught? That was only like 3 1/2 weeks of useage. All of that would be normally sucked back into the intake and end up on the back of the valves because there is no fuel to wash it away. So yes it will help, not cure the issue but slow it down alot.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    Catch can will definitely reduce carbon on the valves as well as oil throughout the intake.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Aug 16 2017
    Killeen, Tx
    Oil in the intake also lowers your fuels octane.
    Aug 08 2013
    Aug 16 2017
    Killeen, Tx
    Bump $250 shipped
    Veteran Member Four Rings kjeeper10's Avatar
    Dec 07 2017
    2007 Jeep Wrangler JK
    Work on B8.5?
    2015 Daytona S5 - Madico Ceramic Tint 35/20 - 6 Speed - Mods - Sprintbooster V3 - APR Stage II - Dual Pulley - CPS Cooler - Eurocode ST Shifter - EuroImpulse weighted knob - USP SS Clutch Line - 034 SD Engine Mounts - 034 Trans Mount Insert - 034 rear SB - CR-15 - ORT Coilovers - SPC Front CA’s - IE Non Res Downpipes - AWE touring w/ 102 tips - CTS intake - ECS Streat Shield - Deval CF Splwitter/Rear Valance - Signature SV901 Forged 19x10.5 wheels - 275/35 Mich PS4S Tires.
    Aug 16 2017
    Killeen, Tx
    Not sure
